Old 15-05-2008, 09:32 AM   #1
Dennis8
Dennis8's Avatar
Default Auto box removal/installation on MK11 esky 2.0L
Hi,
Just after a bit of advice, my bro-in-law has a mk11 2l auto escort, starter motor occassionally won't engage, we start it by turning the engine over by the fan belt (barley moves but enough) then starter will engage ok, I'm removing the starter on friday night to check the teeth on it, but if I find the flywheel is rooted, obviously gonna be a much bigger job.
I'm ok with removing gearbox, done a few manuals in my time on my own on my old Fiat, and an XY too. I'd like to know if theres any tricks to reinstalling the box, does the torque converter bolt up to the flywheel? Then input shaft slide into the torque converter? more to it than that?
Also anything I should know about replacing flywheel? how does it match up? On my XY (Cleveland), the bolt holes would only match up one way, will this be similar? and how tight? We have a torque wrench, just need numbers.
Appreciate the help.
Dennis
Dennis8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2008, 06:07 PM   #2
JamesR
take starter motor out, then turn crank till you can see flywheel/torque converter bolts. i think there's only 4.
the converter stays on the input shaft.
flywheel/ring gear is held on by 6? bolts.
honestly, if you can, take the motor/gearbox out as one, as some of the bolts on the bellhousing are a pain in the a.. to get too.
first of all though, take starter out and get that checked/ reco'd.
ps, do you think you could take a pic of the throttle linkages, cable and kickdown cable brackets?
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 08:40 AM   #3
Dennis8
Dennis8's Avatar
any idea on how tight to do the bolts for flywheel and torque converter?
I'll try and get some pics for you, its completely original so hopefully will show what you're after. PM me with your email address so I can send em through next week.
Dennis
Old 16-05-2008, 11:02 PM   #4
JamesR
Dennis
not exactly sure on correct tension, but i just did mine up tight..
haha
cant be bothered with a pm, so my email is, seekand_destroy@hotmail.com
cheers.
my photo blog;
