15-05-2008, 10:05 PM | #1 | ||
Teh Baest
My mate and I can't really find anywhere to run power cables through the firewall?
He said it looked like the power cable actually ran underneath the car, but he didn't particularly want to do this.. Is there any other way to run the wiring? Cheers
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ) |
15-05-2008, 10:10 PM | #2 | ||
Teh Baest
Search is a good tool isn't it...
LoL
15-05-2008, 10:12 PM | #3 | ||
Is it an auto? If so use the hole for the clutch cable
15-05-2008, 10:15 PM | #4 | ||
Teh Baest
Yeppers
I think that's what i'll be doing Where exactly is it?
15-05-2008, 10:18 PM | #5 | ||
Teh Baest
Actually just found some pics from someone elses car on this forum
Hopefully the 4ga will fit thru it
15-05-2008, 10:21 PM | #6 | ||
You'll find it, in the engine bay to the right and down from the brake booster, kind of a tube sticking out, and to the left of the brake pedal in the footwell. Once you've run it all and have everything setup (so you know lengths are right) rap a cloth around where the cable exits the metal tube in the foot well, and fill it up with sikaflex from the engine bay to prevent the sheath rubbing back.
15-05-2008, 10:23 PM | #7 | ||
Teh Baest
Cheers mate
I'm sure this info will help heaps on the weekend if it gets done Will def post pics of the completed install Already have my deck + front splits in, no amp no nothing and it already gets damn loud.. Looking forward to the monster subs and HUGE amps I should feel right at home in a maccas carpark at around 1am
16-05-2008, 01:13 PM | #8 | ||
The Monty
4guage should only 8 guage i heard is a really tight fit
16-05-2008, 01:18 PM | #9 | |||
Van Mad
16-05-2008, 01:22 PM | #10 | ||
Sales Representative
I used the hole for the bonnet release cable... and i used 4ga...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
17-05-2008, 12:19 AM | #11 | ||
The Monty
lol my bad, thats what i ment 4gauge.. yeah but he is going to use the clutch cable hole. haha
17-05-2008, 12:44 PM | #12 | ||
Teh Baest
Looks like an aftermarket alarm or something is using the clutch cable hole :(
17-05-2008, 12:50 PM | #13 | |||
17-05-2008, 03:58 PM | #14 | ||
Teh Baest
LoL
I might have to Although i tried stuffing the power cable through the same hole as the aftermarket alarm cable and it seems like it MAY go through JUST
17-05-2008, 03:58 PM | #15 | ||
you could just drill a hole in the firewall, I did mine on the left hand side on the bottom right it came out just around the foot rest pedal, il throw a pic up if i can find it.
17-05-2008, 10:47 PM | #16 | ||
I am running my 4ga power through the clutch cable hole with grommet.
17-05-2008, 10:59 PM | #17 | ||
The Monty
wel..im be quiet then
19-05-2008, 11:33 PM | #18 | ||
Teh Baest
Ended up running it through the big grommet just above the bonnet release cable.
Took a while to get it through, but it's there now Now the next fun part... Getting the speaker cable through to the door...
20-05-2008, 03:10 PM | #19 | ||
cant you just use the cars stock wiring? although when i get new speakers i think id rather run fresh wires.
20-05-2008, 03:21 PM | #20 | ||
ORSM Ford Cruisers
i ran 4ga throught the clutch cable hole and i also used the cars stock wiring for the speakers (fronts only) so didnt have to muck around putting a wire through the door.
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
20-05-2008, 04:32 PM | #21 | ||
Teh Baest
At the moment i am running the fronts off the stock wiring, but im putting in a T400-4 amp in the not too distant future. Would rather have some 10ga wire for that
I bloody did it the other day, taped the wire to a coathanger, got it through the door and into the firewall, then using some pliers to get it through the firewall.. Finally got the coathanger through and was thinking YESSSSSS!! Then noticed the wiring was no longer attached to the coathanger... BASTARD
20-05-2008, 04:43 PM | #22 | ||
Why did you go from the door through the firewall? you mean to inside the kick panels?
20-05-2008, 07:02 PM | #23 | ||
Teh Baest
LoL
kick panels my bad lmfao
20-05-2008, 07:48 PM | #24 | |||
20-05-2008, 07:56 PM | #25 | ||
Teh Baest
Was just seeing if you were paying attention :voldar02:
