Closed Thread
Old 25-06-2008, 01:24 PM   #1
bob 351
MIGHTY MAGPIES 2010
bob 351's Avatar
Location: yarram se vic in the shed listening to pinkfloyd and rubbing panels
Default a question regarding stock absorbers
so just wondering if i lower the front of my xc with proper v8 lowering springs do i have to use lowering shock absorbers as well thanks for any info
myblog
I LUV ME FLOYD
for sale xc parts pm me for detail
bob 351 is offline
Old 25-06-2008, 01:27 PM   #2
Fev
Fev's Avatar
changing the shocks will always be reccomended but depending if you wanna drop it more then 1.5-2 inches you shouldnt have any problems. just a rougher ride
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline
Old 25-06-2008, 03:04 PM   #3
bob 351
MIGHTY MAGPIES 2010
bob 351's Avatar
So I Am Not Sure What You Are Saying Fev Can I Use Normal Height Shockies On A Lowered Car Or Should I Buy Lowered Ones I HAVE JUST PUT 2 INCH LOWERING SPRINGS IN IT
myblog
I LUV ME FLOYD
bob 351 is offline
Old 25-06-2008, 03:18 PM   #4
Fev
Fev's Avatar
See how the ride is before you go doin anythin else then.. Or ask a suspension specialist if it may cause any damage.. usually the only problem is a bad ride since theres less travel in the shocks because of the lowered springs
You can use standard shocks with lowered springs. most people do but if you wanna keep a good ride and extra handling because thats taking 2 inches out of the shock travel get some sports shocks for it
Insta@mooneye_ghia
Fev is offline
Old 25-06-2008, 03:52 PM   #5
ebxr8240
Performance moderator
ebxr8240's Avatar
Depends on suspension travel on bump if the coil spring doesn't bind or hits bump stops .. The shock rod maybe too long ... a way around this is to space the top of shock higher with longer bolts and spacers under tripod on top of shock mounting
Daily driver GTE FG..
ebxr8240 is offline
Old 25-06-2008, 04:23 PM   #6
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
http://fordforums.com.au/showthread.php?t=11217698
Falcon Coupe is offline
Closed Thread
