Old 04-07-2005, 06:45 AM   #1
FoxMulder
Default Instrument cluster update. How?
I was wondering if anybody could tell me how to safely open up the instrument cluster, so I can change the faceplates over. I have got some custom ones being made now, by this guy: Speed Graphics Instrument Design and would like to quickly do the mod, (as I drive this car around alot)
Is there any way for me to do this mod, without screwing up the settings, or will I have to take it to an engineer so that it would be properly calibrated.
Thanks,
BTW, this is the design i've ordered. I reckon it would look great on the XR8!
FoxMulder is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2005, 08:30 AM   #2
TUFED6
TUFED6's Avatar
All you have to do is-
  • Undo the top flat-blade screws that hold the cover on, then on the back of the cluster there is 4 phillips head screws that have to come out.
  • Then you can take the cover off and get access to the dials.
  • Take note of the positions that the needles rest on, then you will need to evenly lever the needles off. I used two small flat-blade screwdrivers either side. Some force will be required but try to be carefull.
  • Once you've got the needles off the tach/speedo you can undo the small phillips head screws on the dial and lift the top layer off.
  • Pretty much just repeat for the smaller 4 gauges.
Putting it back together is the reverse, but make sure you put the needles back on in the same positions as they were.
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2005, 01:18 PM   #3
InitialD
Low and Loud
InitialD's Avatar
Mulder... the truth is out there err i mean :P
nice looking cluster man, where you getting that from?
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2005, 02:37 PM   #4
mcflux
mcflux's Avatar
From here ;) ;)
Old 04-07-2005, 06:51 PM   #5
FoxMulder
Initial D, the cluster design is something I did on the other forums, when Psycho Chicken was thinking about making some up. I created a whole heap of different variations for the Sports cluster, but this type was my favorite.
Thanks TUFED6, I was just worried about the dials becoming inaccurate. I heard that putting extra weight on the needles was a bad thing, as that tended to make it inaccurate. I was just wondering, because I wanted to paint my needles red.
Old 04-07-2005, 09:59 PM   #6
mcflux
mcflux's Avatar
You shouldn't worry about the weight of the paint on the needles! If the weight of a single needle is say 10g, I'm sure the paint on it is <0.05g.
-Dave-
