not here much anymore
Guys
Ive got the above phone but the navigator never seems to want to work, do I have to do something specific to set it up? Im with Virgin if that helps
2024 F150 XLT
i have the same phone
but i am not with virgin ( dont think that would be the prob ) in the 6110 it is a stand alone gps reason i went with it for some reason it does take a while to log onto the network i would give it a good 2-3 mins to find the satalites ect mine depending on conditions can take a good 4-5 mins to log on if it doesnt log on in that time you may have a faulty unit hope that helps jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
G'day mate ive got one of these phones, and found a firmware update helped alot. It can make a difference sometimes, depending on the errors you are getting.
Here's the Nokia Link: http://www.nokia.com.au/A4612230 You can also update the Route66 software for these phones, I think you get a free update for the Australian maps too (can't remember the exact update I got free, I think it was Q42006 or something like that). You have to install the Route66 software from the CD that came with the phone, then update from there. Hope that helps.
For Work: '95 EF Fairmont For Play: '03 BA GT-P |
I also think by default these phones have what it called ActiveGPS, which downloads a list of satellite locations to aid with GPS locating (ie supposed to make it quicker etc). You could check to see if it is enabled, and if not enable it and see if it can connect to GPS. Without this enabled, it can take a couple of minutes to get a GPS fix.
To check if it's enabled or not, you go into the Navigator application, then Options > Settings > Extras > Network Connection. It does cost extra, however, because it is considered the same as a data download.
I'll try for an update on my n95 tommorrow as so far I think its a waste of space
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
Thanks guys, Ill have a look into it. I dont use it at all but it does bug me that there's stuff on there that doesnt work.
2024 F150 XLT
I can count to potato!
Also pays to note that like the n95 you must have slide the keypad out when using it for navigation as the the GPS receiver is under the 8 button.
AU III XR8 UTE |
I use the same phone and its excellent, Ive got red light cameras etc all loaded in as well
![]() The delay is because the gps receiver in the phone takes a bit but once it grabs it, it works quick the next few times. You can quicken it up buy turning on a feature that allows the phone to connect using the internet and it finds you in the matter of seconds im led to believe, but then it costs DATA on your plan which can cost alot depending on what data amounts you have on your plan. As above update the firmware. And i find the maps not tooo bad, but will be looking for the update when its about. Its not the best fora pure street navigator, but is very handy still if you don't have one. |
I have the same phone on Virgin and no problem,
The GPS will take some time if you shut it down say on the Gold coast and then try to use it again in Brisbane the phone still thinks its on the Gold Coast, they find themselves quicker if they are turn off and on in similar places. I would take it back to where you bought it. good luck |
