Old 06-08-2008, 05:28 PM   #1
sweetswan
Default Sierra 5 speed
Does anyone know of any difficulties putting a sierra 5 speed in a 1980 1600 4 speed panel van? Or is it a relatively pain free swap?
cheers
sweetswan is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2008, 08:45 PM   #2
Escort_RPDriver
you will need an auto tranny tunnel to fit it a stock manual tunnel is to small fro a 5 speed i think
Escort_RPDriver is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2008, 09:47 PM   #3
Sterling
as far as i know 5 speeds fit... should probably look into it, but if i remember correctly the sierra 5 speed is like the only 5 speed that can fit in a manual tunnel.
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2008, 05:11 PM   #4
whooligan
whooligan's Avatar
Its basically the same box as the 4 speed with an over-drive so the extension housing is a little chunkier and the shifter hole needs to be a little further back. If you are putting it in a mk 1, you need to space the mounts to sit it lower. Use your original gearbox mount and it should fit ok.
Old 07-08-2008, 05:29 PM   #5
sweetswan
thanks for that. cleared things up. cheers
Old 13-08-2008, 02:10 PM   #6
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
Ditto, What i have done to my mkII to fit.
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2008, 07:56 PM   #7
Kingsley
Which Fords available locally do the Sierra 5 speeds come installed?
Kingsley is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2008, 08:19 PM   #8
V8falcons
V8falcons's Avatar
that would be nil
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
