Old 07-09-2008, 02:44 PM   #1
paddy
Default Car Flooded
I was driving yesterday in my ba xr8 and went through a part of the road that was flooded. Went through slow and water was below the base of the door but the car cut out and won't start. When you try and kick it over it sounds like a flat battery but its not. So i think it must have swallowed some water but what type of car can't go through water that shallow? I mean crappy little echos were making it. Any thoughts on what it could be?
paddy is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2008, 02:48 PM   #2
TC200six
There are many things that could cause that, obviously water got into some ignition device. Has it dried up, Does it start now?
TC200six is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2008, 02:52 PM   #3
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
Sounds like your starter motor has taken in water, you'll probably find the solenoid connections are wet, if you have access to compressed air try giving it a good blast and dry it out !!
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2008, 04:04 PM   #4
nj351
Ultra White
nj351's Avatar
Sounds like you glupped up some water try the electricals first if not take the top off your inlet manifold take plugs out and clean it all out
played with many falcons with water damage and most are still driving now with no problems
MID NORTH COAST FORD OWNERS CLUB MEMBER NUMBER 351
nj351 is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2008, 10:54 PM   #5
XR Martin
XR Martin's Avatar
Pretty sure an Echo sits a bit higher off the ground than an XR8 ute....
2004 BA wagon RTV project.
Old 08-09-2008, 09:29 AM   #6
alecrain
'03 BA XT
alecrain's Avatar
Cool
Spraying suspected components with WD40 should also help!!!
Melbourne family photographer -Discount for AFF members (PM me first) :
Beautiful Photography Blog
2003 BA XT
IMPCO SVI - TYPHOON CAI +XR6T snorkel - K&N Panel Filter - DBA Slotties - Tint
1998 Toyota Landcruiser Prado
www.bseries.com.au/alecrain
People that drive slower than ME are BAD DRIVERS,
People that drive faster are IDIOTS
alecrain is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 11:01 AM   #7
RAREV8
Previously ScottishXC
RAREV8's Avatar
Also check your filter hasn't taken a load of water in- this shouldnt stop it cranking but while you are under the hood it should be checked....
I did the same to mine but WD40 and a good drying out had her working again pretty quickly.
Great transactions with the following members:
BJ
Gilesie
XAGTCoupe
Pilch
Aussie_afroman
Donut King
Bad Boy Benny
BAWITHLOT
Greenmachine
Pinkbits
CUZ351
OhioXB
Falconunbelievable
4VXC
Uncleraggy
FG G6 Ego, tech pack, Tropic gold 1973 Landau, Cosmic blue 1975 P5 LTD....long term project
Originally Posted by 4Vman
Im just bored of the single/narrow minded...
RAREV8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 08:43 PM   #8
bawag
bawag's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Providing easy to follow photo tutorials for members on how to replace tierod ends on a Cortina.
How did you go?
bawag is offline   Reply With Quote Multi-Quote with this Post
