Old 14-07-2005, 05:25 PM   #1
ea007
Default diff help
after some diff info i have a 75 model 2 door mk11 it has a removable center was wondering if this was a standard diff in the 1600. it is 3.93 ratio can you get a 3.25 or similar ratio to fit. any help would be appreciated.
ea007 is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2005, 11:07 PM   #2
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
As far as I am aware, the tallest ratio you can get is a 3.54:1, not sure why you'd want a ratio any taller then that...
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2005, 02:15 PM   #3
ea007
country driving all of its life so want good legs over acceleration. plus are they removable centre or integral
mine has been modded and i am unsure if it is standard
Old 15-07-2005, 06:37 PM   #4
Paul735
It doesnt work like that if you put in too tall a diff the engine works very hard and you use LOTS more fuel, ask anyone that has put big tyres on a 4x4 less rpm but more fuel overall.
Paul735 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2005, 06:58 PM   #5
The MaDDeSTMaN
yeah, it looks like it has been modded, unless it's an imported RS2000, either it's had the RS2000 front end grafted onto a 'normal' Escort, or it's a later year then '75...
If its a '75 Escort, and not an imported RS, then it also wouldn't have originally had a 2000cc "Pinto" OHC engine, it would have had either a 1300cc or 1600cc "Kent" pushrod OHV engine.
What does it say on the compliance plates, just the model #, engine and trans codes?
I say that because I know my Escort was originally an XL 1600, but now it's got GL badges, a Ghia interior and instrument cluster and a 2000cc pinto under the hood...
Old 15-07-2005, 07:07 PM   #6
The MaDDeSTMaN
exactly, unless you're spending 95% of your time cruising at 140km/h or higher, and holding the speed steady, you would regret going for a taller diff then a 3.54:1. 3.54:1 diff would give you about 3000rpm at 100km/h, whereas 3.77:1 diff (same as what I've got in mine) gives about 3200rpm at 100km/h. Much taller then a 3.54:1 diff ratio and you'll be needing to go back to third gear to overtake at 100km/h, in which case you'd be using more fuel then simply leaving it in 4th and putting the foot down a little.
Not sure, I can look it up, I'll have a look and get back to you.
Old 15-07-2005, 07:14 PM   #7
The MaDDeSTMaN
Oh yeah, you'd probably benefit much more from slotting a 5 speed box behind it then changing the diff ratio. Personally, I'd go for a sierra 5 speed box, pretty easy to fit and same ratios in 1st to 4th, but with an overdrive for 5th.
I think you'd be more then happy if you swapped the 4 speed for a 5 speed
Old 16-07-2005, 10:41 AM   #8
ea007
ok thanks for the help. it does i found the engineer cert for all the mods. used to be a 1600 had a rs2000 front and a group 3 flare kit of rallicross(genuine ford), it has 14 inch wheels so i will try 3.54 first. 10 point rollcage and no back seat
Old 18-07-2005, 08:16 PM   #9
T3man
T3man's Avatar
Capris have a 3.22 diff - much bigger ring gear than Escorts but I think the centre distances on the spring eye bolts are the same, so if you found one you could bolt it in drum to drum ... still, I reckon you're better off with a five speed.
Old 23-07-2005, 09:40 AM   #10
ea007
thanks for the input had someone suggest fitting a mx5 motor and 5 speed box leaving the current 3.93 diff as the mx5 put out about 75kw from a lighter lower capacity engine. any thoughts ????
Old 23-07-2005, 11:53 AM   #11
The MaDDeSTMaN
Sounds very interesting to me...
