Old 23-03-2009, 04:03 PM   #1
noosacuda
noosacuda's Avatar
Default weekend project- fit a six pack
This is what i did last weekend to my Chrysler 300......
noosacuda is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2009, 04:14 PM   #2
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
Holley 2300's ?
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is online now   Reply With Quote Multi-Quote with this Post
Old 23-03-2009, 04:22 PM   #3
cs123
cs123's Avatar
I think I need to see a picture of the 300.
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 23-03-2009, 04:40 PM   #4
AUIIForte
I call a fake. The panels (inside of the engine bay) do not look anything like a Chrysler 300.
Unless you couldn't get pics of it, so just showed pics of your old car.
AUIIForte is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2009, 04:43 PM   #5
ZA-289
ZA-289's Avatar
I hope your not assuming this is a 300C
ZA-289 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2009, 04:45 PM   #6
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
I think he would be perhaps talking about the original Chrysler 300. And the set-up if the normal Chrysler route when going triples has two x 500 Holleys and a single 350 Holley with a progressive throttle linkage so light throttle only uses the 350 with a pair of 500s coming into play as throttle is opened wider.
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2009, 04:45 PM   #7
cs123
cs123's Avatar
Fake?? I think he is talking about something like this
http://static.howstuffworks.com/gif/...vertible-1.jpg
It's pure horn
Old 23-03-2009, 04:57 PM   #8
Unco
Unco's Avatar
that looks awesome. what did you have in it before the 6 pack? and has it made much of a difference?
Unco is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2009, 11:26 AM   #9
noosacuda
noosacuda's Avatar
No fake, it's an OEM set up- Edelbrock manifold,2 x 500 cfm vacuum operated 2ndries and a 350 cfm central carb with a progressive linkage, (factory rated 390hp).
NOT A FAKE. It had a single 750 Edelbrock previously. It's in a 1966 Chrysler 300 coupe that weighs approximatly 2300kg's. In a 1966 road test with a 440 (365hp)single 4 bbl on cross-ply tyres they used to do 15.2 second 1/4 mile times.
