Old 04-08-2005, 05:00 PM   #1
FordFan86
meow
FordFan86's Avatar
Default Tickford Snorkel on E-Series
Got a couple of tickford snorkels here, i know i have to melt mine to clear the power steering pump (5litre NC) so i went to work on dad's 6cyl EF and thought it was a direct swap?! :S seems that the thermofan cover is in the way? can someone help me out here :gren:
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2005, 05:03 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
Force it!
Old 04-08-2005, 05:20 PM   #3
FordFan86
meow
FordFan86's Avatar
and done
unscrew three bolts holding airbox down so there is a little movement, force it in, screw it all down, nice and firm.
Old 04-08-2005, 05:20 PM   #4
LUXO_8
windsor user
ah i remember that problem
as well as heating it to clear the the powersteering pump, you have to cut a little bit away from the part where the snorkel goes against the airbox, then put a new screwhole in the snorkel itself to mount it to the radiator cover piece
then you have to fiddle with the rubber strip on the bonet which goes around the snorkel, as the snorkel will be in a slightly different location to factory
EDIT,
i didnt read your initial post properly.....thought it was for your 5.0 :gren:
