Old 04-08-2005, 11:50 PM   #31
EFFalcon
Last warning
EFFalcon's Avatar
good to see someone supporting what i said.
my EF used to rev out happily, my parents AU hates it.
exhaust mods would help top end on AU's greatly.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 04-08-2005, 11:52 PM   #32
Damo
My dad's current AU2 strait gas is about on par with an auto MPI EA. No Sh!t! It's soo gutless, his BA E-Gas was pretty hopeless too. He misses his old AU1 duel Fuel, my dad like the grille, plus it went hard.
Autos suck, when will you people realise this and start buying manuals. Manual falcons from EA >> are just becoming soo damn rare (not including XR models). It sucks! I've only ever seen a maybe 5 manual AU Fortes/Futuras.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2005, 11:53 PM   #33
dansedgli
dansedgli's Avatar
My auto goes fine
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2005, 12:10 AM   #34
Damo
6 speed would go better. ;)
Pull all the performance gear off and see how it goes Dan. :P My old EA would Probably give a stock AU auto a good run for it's money.
Old 05-08-2005, 12:53 AM   #35
MickyB
Get in the ring!!!
MickyB's Avatar
Originally Posted by dansedgli
My auto goes fine
I bet most autos would feel a bit toey with 308rwkw! Seriously though, if you have a non turbo falcon the difference between manual and auto is amazing, it's like doing heaps of mods and going for a drive, the 1st gear ratio in auto's is terrible.
In keeping with the topic however I agree with EFFalcon in that my dad's EF felt great up high but not as toey off the line, while his AUFutura would just light em up off the line but run out at about 4000 rpm. When is 157kw different to 157 kw I wonder, stock dyno curves would be nice
FG MKII XR6T - Tuned by Pit Lane
MickyB is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2005, 01:16 AM   #36
EFFalcon
Last warning
EFFalcon's Avatar
AMusingly enough, the powerchip website has dyno graphs of stock engines.
it suggests opposite to what we have, with the AU having 160kw and the EF having 157kw.
EF has a tiny bit more mid range, AU has more up top.
[img]hxxp://www.deleted link/pics/enginecomp.jpg[/img]
Old 05-08-2005, 01:37 AM   #37
Walkinshaw
Two > One
Walkinshaw's Avatar
The AU's i have driven feel really torquey down low yet are anemic above 4000rpm compared to my EL (not stock but you get the idea).
Old 05-08-2005, 01:38 AM   #38
EFFalcon
Last warning
EFFalcon's Avatar
i guess the extra mid range of the AU helps just enough to give it the advantage, the exhaust mods bulk out the mid range and increase teh top end considerably.
Old 05-08-2005, 02:07 PM   #39
XRated
Shoot.
XRated's Avatar
AUs are better!
/Runs
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2005, 02:37 PM   #40
Stav
Smile
Stav's Avatar
The AU falcon has different pistons...I think they are called hyperpeutic?The Au is supposed to have a bit higher compression too.
I had also read an article a long time ago that the AU transmissions were used original in older model mazzeratis.
I had an eb before and it felt alot quicker off the mark than my AU...hence the begiining of mod addiction.
The eb at midrange felt like it died down a bit.The Au on the other hand seems to pull harder at these speeds.
The eb felt much lighter than my AU by heaps,but I am not sure if it was.
Also the size of the valves on the au seem to be possibly bigger than prior cars inlets are 47 mm and exhaust are 41 mm.Maybe someone knows some specs on the older cars to compare.
Old 05-08-2005, 02:47 PM   #41
Walkinshaw
Two > One
Walkinshaw's Avatar
The pistons in the AU im not sure if they are hyperutectic (a method of construction), but they have a diffrent pin position and longer rod, thus making less side wall thrust which aids in mid range torque. The AU also had an extra 3 points in compression iirc.
The AU head runs a 41mm exhaust valve over the Eseries head. The cam profile was also changed with the LSA out to a 119deg.
A similar/fair comparison would be EF2/EL XR6/F'Ghia Auto Vs AU Fairmont Auto
Old 05-08-2005, 06:53 PM   #42
Stav
Smile
Stav's Avatar
I am definatelty sure about the piston being hyper ..whatever.
Old 05-08-2005, 07:50 PM   #43
Walkinshaw
Two > One
Walkinshaw's Avatar
Being Hyperutectic wont increase power in itself, just a better material than cast.
Old 05-08-2005, 07:52 PM   #44
dansedgli
dansedgli's Avatar
I thought eb 2 onwards had hyper's.
Old 05-08-2005, 08:01 PM   #45
Walkinshaw
Two > One
Walkinshaw's Avatar
wouldnt supprise me Dan. the cost between manufacturing cast vs Hypers, isnt huge, as it is not a forging process.
Old 06-08-2005, 09:13 AM   #46
LOWAU
___________
LOWAU's Avatar
My car is an AU1 auto Forte with 4499 paces, high flow cat, 2.5" exaust and simple air intake mods(filter and ef box) I ran a best of 15.62 with a 2.4 60foot. I reckon I can crack into 15.5 with the same setup. Its a stock diff as well.
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2005, 09:18 AM   #47
Kenaz
Kenaz's Avatar
Easy as. Work on that 60ft and you'll get there easy.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2005, 03:51 PM   #48
Wicherts
Hi all.
Ive got a 96 EF 6cyl Gli 5sp Manual that now has a fair few mods. But when I only had a cold air intake I was doing 7.6sec 0-100 and there was an EL XR8 Auto that could not get under 8 sec.
Old 06-08-2005, 03:58 PM   #49
Wicherts
Hi all.
Ive got an EF Gli 6cy Manual that has got a fair few mods. I was out at Oran Park a couple of months ago and at the time I only had a Cold ait intake. I ran 7.6 sec 0-100 . There was an EL XR8 Auto that could not get under 8 seconds.
Old 06-08-2005, 04:11 PM   #50
GlennBA
GlennBA's Avatar
AU futura's never came in manual, so no wonder you haven't seen many, AUI fortes came in manual, but not the series 2 afaik, only the series 2 S and SR were available in manual, and the AUIII fortes were available in manual.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2005, 04:19 PM   #51
EFFalcon
Last warning
EFFalcon's Avatar
you couldn't get an AU II Forte Manual?
what a jib!
Old 06-08-2005, 04:22 PM   #52
Wicherts
Hi there. what are you doing 0-100
Old 06-08-2005, 04:25 PM   #53
EFFalcon
Last warning
EFFalcon's Avatar
the Brochure scans state the AU II Forte's are Manual standard, with the Auto optional.
just like all base model falcons...
Old 06-08-2005, 04:27 PM   #54
GlennBA
GlennBA's Avatar
my mistake then. I just saw on rebook it didn't have an option for auii forte manual and checked on carsales and couldn't finy any AUII manual forte.
Old 06-08-2005, 04:29 PM   #55
Wicherts
Default none
Does anyone know roughly how many manual Gli's were made
Old 06-08-2005, 04:32 PM   #56
EFFalcon
Last warning
EFFalcon's Avatar
no idea what my car does 0-100.
never tested it..
my cars auto so it wouldn't be that good.
the manual GLi's are pretty quick, the 5 speed livens these cars up substantially.
