Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 01-06-2009, 06:21 PM   #1
blake fergo
blake fergo's Avatar
Default bf xr8 quote
hey mate iam not really sure what i would need but iam after i guess a brake upgrade i have a bf xr8 ute with standard brakes atm and was lookin for better ones i have no idea about brakes thats my down fall what would u recomend and prices cheers
drive hard drive fast but drive smart :
blake fergo is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2009, 02:47 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
No problems but can you tell me a few things so i can narrow down what we can do.What size wheels do you have and what you will be doing with the car and how much you have budgeted for this.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
FLOORED is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2009, 04:55 PM   #3
blake fergo
i have stock 17 atm and would like to leave them on cos ive got them sprayed black and look quite effective
daily driving and takin it down the strip as well and the budget not really sure just wanted a price so if i did want to go down that path i wouild no what iam gettin myself into thanks
Old 02-06-2009, 06:40 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
You could run the BF XR8 front brakes which would set you back about $1500 with braided lines,slotted 322mm rotors,calipers and decent pads.The other option is to go to a 4 piston kit with 330mm rotors and that will cost you about $3150
MATTHEW PEARCE
Phone 02 9609 1101
Old 02-06-2009, 06:56 PM   #5
blake fergo
haha see i don't really no what that all means could u explain it a bit better to me haha sori if it annoys you just will that mean i will stop better they won't heat up as much won't need replacing as much ??
Old 02-06-2009, 07:32 PM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Basically the cheaper kit is better than the ones you have on the car now but the dearer kit is better than the cheaper kit.(lol)
If you have the money ,the dearer 4 piston 330mm kit is going to have the best braking for you as they are better designed and will have way better stopping power and shorter stopping distances.The alternative kit that is cheaper is still a twin piston caliper like what is on the car now but will run with the larger 322mm disc rotor and will be a better option than the factory brakes you run now.
You can ring me during the day if you like on 02-9609 1101
MATTHEW PEARCE
Phone 02 9609 1101
Old 02-06-2009, 07:46 PM   #7
JOHNNOSF6
Shouldnt he already have the twin pot claipers being a BF
JOHNNOSF6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2009, 12:48 PM   #8
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thats correct but they are designed to suit the 298mm disc and will not fit over the larger rotor.The XR8 and XR6T version which is what we base the cheaper kit off has 322mm rotors and the caliper is designed to fit this size.
MATTHEW PEARCE
Phone 02 9609 1101
Old 03-06-2009, 01:44 PM   #9
JOHNNOSF6
Ah i didnt know the BF xr8s had 2 different rotor sizes, thanks for the info mate.
Old 03-06-2009, 02:23 PM   #10
FLOORED
Race Brakes Sydney
FLOORED's Avatar
BF Series
Front 298mm vented
Rear 303mm solid
BF XR6T and XR8
Front 322mm vented
Rear 328mm vented
MATTHEW PEARCE
Phone 02 9609 1101
Old 03-06-2009, 04:49 PM   #11
JOHNNOSF6
If his is a BF xr8 ute then he should already have the 322mm fronts correct
Old 03-06-2009, 05:01 PM   #12
FLOORED
Race Brakes Sydney
FLOORED's Avatar
e Yes it should have the 322mm set up.I have no excuses
MATTHEW PEARCE
Phone 02 9609 1101
Old 03-06-2009, 06:33 PM   #13
FLOORED
Race Brakes Sydney
FLOORED's Avatar
There is a AP racing kit which is complete front and rear for $5500 that will fit 17" wheels that i forgot to mention.
MATTHEW PEARCE
Phone 02 9609 1101
Old 03-06-2009, 06:44 PM   #14
blake fergo
so what would u suggest if i didnt want to spend a fortune and wanted better brakes ? not the best but beter
Old 03-06-2009, 07:11 PM   #15
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The only upgrade you can fit is the AP Racing 4 pot and that is $3150 plus fitting.If that is over what you want to spend i would suggest the dba 4000 series rotors and DS Performance pads that will set you back about $1300 all round plus $220 fitting.
MATTHEW PEARCE
Phone 02 9609 1101
Old 03-06-2009, 08:57 PM   #16
blake fergo
cheers mate ill be in touch
