Old 18-05-2009, 04:31 PM   #1
aye you
The Origional, The Best
aye you's Avatar
Default So i changed my Dash fascia over
hey all,
i've changed my dash fascia to a silver fascia. the same colour as the Tickford ones that also lights up blue, but for the Forte dash. Now, apart from the speedo over reading by 5kph (check with GPS) when the car is turned to acc power the speedo needle 'dances' around from 0kph to the rear stop until the car is either started or turned off. anyone know why the needle would be doing this?
i'll post pics tonight and a vid of the needle in my build thread after work.
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2009, 05:25 PM   #2
BFD83
BFD83's Avatar
Don't always rely on GPS speedo's man they are not always accurate. As for the needle "dancing" around i rekon it must not be on properly for it to be doing that.
BFD83 is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2009, 06:02 PM   #3
NYTEYZ
Same problem i had when i changed my facia, the needle is on properly but is on in the wrong spot, easyest way to fix this and get your speedo a little more accurate is to take the needle off, start the car with the dash plugged in, and then push the needle on at Zero km/h. That will eliminate the 'bounce'.
NYTEYZ is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2009, 06:02 PM   #4
dreadly
When putting dials back on you have to wind them around once- then when you start up they'll be back at 0 instead of dropping down?
dreadly is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2009, 10:14 PM   #5
aye you
aye you's Avatar
@ Brent: man i hope this GPS is accurate, i use it when flying ;)
Dreadly, you mean a full counter clockwise turn? might just follow NYTEYZ idea and just put it back on when the car is running
Current Mods
Future Mods
Old 18-05-2009, 10:38 PM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
GPS is almost pinpoint accurate for speed. Way, way, way more accurate than some dodgy mechanical guess drive speedo like cars are fitted with.
Old 18-05-2009, 11:32 PM   #7
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
GPS is not accurate for speed, it can not take into account terrain, hills and so on, it is also only accurate to 10metre's of distance as well, unless u use multiple ground units and then its highly accurate to 1/10ths of millimetre's.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2009, 10:26 AM   #8
Sox
RIP...
Sox's Avatar
Whilst most of that is true, a GPS is still far more accurate than the speedo in your car.
10m of distance is a tiny amount when travelling at 100kph, which is part of the equation to calculate speed. (Time is of course the other part).
Car speedos are rarely accurate, and can be as much as 10% out.
Oval Everywhere...
Old 19-05-2009, 11:33 AM   #9
dreadly
yep a full anti clockwise turn. And that'll sort it out ;)
Old 03-06-2009, 10:10 AM   #10
AUIIXR8Ute
Automotive Detailer
AUIIXR8Ute's Avatar
Is this needed on all the dials or just the speedo?
I'll be changing my fascia over soon so I'll probably end up with the same problem.
AUIIXR8Ute is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2009, 04:06 PM   #11
BillC
SOX is absolutely correct. I would be betting my money on the accuracy of the GPS over the speedo any day. At 100 Kph on my GPS my speedo is reading 109. If I drive by my speedo cars overtake me all the time.
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2009, 11:27 PM   #12
dreadly
Um speedo and tacho definatly, cant remember with the temp, fuel, and oil?
Old 07-06-2009, 10:49 AM   #13
AUIIXR8Ute
Automotive Detailer
AUIIXR8Ute's Avatar
I'll work it out I'm sure :
I've also been told to wind them to the right (clockwise), start the car and after they have wound back to zero, fit the needles.
Old 08-06-2009, 04:31 PM   #14
dreadly
Na just fit em, then wind anti clockwise and you'll feel em click into place. And i think i did it on all of em. some may need to have the edges lifted slightly in spots for clearance. But once you start you'll know what i mean. Fitting and taking out the dash unit itself is harder lol
Old 08-06-2009, 06:02 PM   #15
ronwest
All Bran = Regular Member
Do the needles just pull off?
I had a bit of a go at it when I changed to blue leds as the orange needles disappear at night. Didn't want to break them so I left them until I work out what to do about that.
Old 08-06-2009, 06:05 PM   #16
fordon
fordon's Avatar
get a fork,stick in under needle and pull upwards,there quite tricky hard things.
fordon is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 06:21 PM   #17
dreadly
Lol it's quite tense, they feel as though there gonna snap and then... "pop" off they come ;)
Old 08-06-2009, 06:30 PM   #18
ronwest
Ok, cheers.
Has anyone been onto VDO or wherever regarding different coloured needles?
Old 08-06-2009, 06:58 PM   #19
AUIIXR8Ute
Automotive Detailer
AUIIXR8Ute's Avatar
Sounds good, the new fascia should arrive this week so next weekend could either be a good one, or I'm going to be in a very bad mood
Old 08-06-2009, 07:04 PM   #20
aye you
aye you's Avatar
or you can rotate them anti clockwise while pulling them off. comes off in 5 turns. thats how I got mine off.
Current Mods
Future Mods
Old 08-06-2009, 07:20 PM   #21
AUIIXR8Ute
Automotive Detailer
AUIIXR8Ute's Avatar
The needles don't screw off though do they? They are just pushed on?
Old 08-06-2009, 08:03 PM   #22
private9
www.TUFFCARPARTS.com
private9's Avatar
I always put a tissue under the fork though, so I don't mark the fascia.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2009, 08:12 PM   #23
dreadly
just pushed on hey ;)
Also handle the unit with care, i blew 2 bulbs stuffing around with mine lol
Old 08-06-2009, 08:17 PM   #24
dreadly
Ok, cheers.
hmmm some different coloured needles sounds alright, and some coloured bulbs too ;)
