Old 24-08-2005, 09:03 PM   #1
sphell
sphell's Avatar
Default Hunting idle
What causes an engine to hunt for idle? Yesterday I thought I got the car idling properly but tonight I took it to the gym and gave it a bit of stick on the way. After that, whenever I pulled up at the lights, I've noticed that it hunts for idle from about 1000-1200rpm. I disconnected the ISC and it's bought the revs down a bit (700-850) but it still fluctuates. If I start the car and drive smoothly, it's fine. What can I do, it's bloody annoying!!!
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 11:13 PM   #2
saudia_man
try using 99octane fuel???
saudia_man is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 11:19 PM   #3
InitialD
Low and Loud
InitialD's Avatar
My car does this occasionally. Its sometimes seems to disappear for a few weeks when I stick the car in diag mode for a few seconds, after this it wont hunt for around 2 weeks then it starts doing it again. I have NFI why :
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 11:36 PM   #4
Walkinshaw
Two > One
Walkinshaw's Avatar
your running a stock cam?
Set the timing in Diagnostic mode to 600rpm when warm with the IAC disconected.
1978 LTD - 408ci - 11.5@120.6mph -
2004 S4 - 4.2 - M6 - quattro -
Walkinshaw is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2005, 07:10 AM   #5
Gubas
- BOOYEH -
Gubas's Avatar
mine does this since i put a manual in. i used the auto ecu for a while, and it fluctuated 200rpm. i have since installed an ea ecu, which apparantly had the auto ecu seperate from main ecu. So, computer problem mabey???
1993 EBII Fairmont Turbo T04e 7 psi
Gubas is offline   Reply With Quote Multi-Quote with this Post
