Old 24-08-2005, 12:11 PM   #1
Casper
Contributing Member
Casper's Avatar
Default Dodge Tomahawk - 8200CC & 510 BHP
ENGINE
1. 500 bhp (372 kW) @ 5600 rpm (60.4 bhp/liter); 525 lb.-ft. (712 Nm) @ 4200 rpm
2. 10-cylinder 90-degree V-type, liquid-cooled, 505 cubic inches (8277 cc)
3. 356-T6 aluminum alloy block with cast-iron liners, aluminum alloy cylinder heads
4. Bore x Stroke: 4.03 inches x 3.96 inches (102.4 x 100.6)
5. Two pushrod-actuated overhead valves per cylinder with roller-type hydraulic lifters
6. Sequential, multi-port electronic fuel injection with individual runners
7. Compression Ratio: 9.6:1
8. Max Engine Speed: 6000 rpm
9. Fuel Requirement: Unleaded premium, 93 octane (R+M/2)
10. Oil System: Dry Sump; takes 8 quarts Mobil1 10W30 Synthetic
11. Cooling System: Twin aluminum radiators mounted atop engine intake manifolds, force-fed from front-mounted, belt-driven turbine fan.
12. Takes 11 quarts of antifreeze.
13. Exhaust System: Equal-length tubular stainless steel headers with dual collectors and central rear outlets
SUSPENSION:
Front:
Outboard, single-sided parallel upper and lower control arms made from polished billet aluminum. Mounted via ball joint to aluminum steering uprights and hubs. Five degrees caster. Single, fully adjustable centrally located coil-over damper ( 2.25-inch coil with adjustable spring perch); pullrod and rocker-actuated mono linkage. Center-lock racing-style hubs.
Rear:
Hand-fabricated box-section steel inboard swing arms, incorporating "hydral-link" lockable recirculating hydraulic circuit parking stand. Single fully adjustable centrally located Koni coil-over damper ( 2.25-inch coil with adjustable spring perch); pushrod and rocker-actuated mono linkage.
BRAKES:
Front:
20-inch perimeter-mounted drilled machined stainless steel rotors, one per wheel. Two four-piston fixed aluminum calipers per wheel (16 pistons total), custom designed. Blue anodized caliper finish. Hand-activated.
Rear:
20-inch perimeter-mounted drilled cast-iron rotors, one per wheel. One four-piston fixed aluminum caliper per wheel (8 pistons total), custom designed. Blue anodized caliper finish. Foot-activated.
The Tomahawk is a Viper V-10 based motorcycle, a 500 horsepower engine with four wheels beneath it.
Chrysler will be selling the original Tomahawk concept and nine replicas through Neiman Marcus, for up to $555,000 each. The motorcycles cannot be licensed, so they cannot be legally driven on public roads. A Chrysler spokesman told Reuters they were meant as rolling sculptures.
Rumors had the Tomahawk selling for under $200,000, most likely at a loss or breakeven price, for publicity purposes - but still fully drivable. Wolfgang Bernhard, Chrysler's not particularly respected first mate, was said to be enthusiastic about that project, so much so that hundreds were projected to be built at under $200,000 each. They reportedly cost Chrysler over $100,000 to build (admittedly the work is outsourced).
The Dodge Tomahawk can reach 60 miles an hour in about 2.5 seconds, and has a theoretical top speed of nearly 400 mph. Each pair of wheels is separated by a few inches and each wheel has an independent suspension. Bernhard said four wheels were necessary to handle the power from the engine.
The Tomahawk remains on display at auto shows - though well out of reach of the general public, elevated on a special display.
PERFORMANCE:
0-60 mph: 2.5 seconds (est.)
Top Speed: 300+ mph (est.)
DIMENSIONS:
Length: 102 inches
Width: 27.7 inches
Height: 36.9 inches
Wheelbase: 76 inches
Seat Height: 29 inches
Weight: 1,500 lbs.
Track, Front: 8.75 in
Track, Rear: 10 in
Weight Dist: 49F/51R
Ground Clearance: 3 in
Fuel: 3.25 gallons
ELECTRICAL SYSTEM:
Alternator: 136-amp high-speed
Battery: Leak-resistant, maintenance-free 600 CCA
Lighting: Headlights consist of 12 five-watt LEDs, front, with beam-modifying optics and masked lenses. Eight LEDs, rear. Headlamps articulate with wheels.
TRANSMISSION: Manual, foot-shifted two-speed
Aluminum-cased two-speed, sequential racing-style with dog ring, straight-cut gears Gear Ratios: 1st 18:38; 2nd 23:25
Clutch: Double-disc, dry-plate with organic friction materials, hand lever actuated with assist Final drive: Dual 110-link motorcycle-style chains
Front Sprockets: 14 teeth
Rear Sprockets: 35 teeth
Longitudinal, centrally mounted engine, rear-wheel drive layout; monocoque construction, engine is central, stressed member. Body of billet aluminum.
Its a MOTORBIKE!!!!! :
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 12:14 PM   #2
merlin
merlin's Avatar
4 wheels??? I wonder how it handles? What a monstrosity!
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop.
Still to go - Holley Sniper EFI with integrated fuel cell.
merlin is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 12:19 PM   #3
Sourbastard
Contributing Member
Sourbastard's Avatar
From certain angles it looks like a Honda 250cc.
1965 XP Falcon Deluxe Sedan
1978 XC Falcon Wagon Rallypack
2003 BA Fairlane G220
Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM
Sourbastard is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 12:39 PM   #4
Velociraptor
Digging for avatar
I love that "we build it because we can" mentality, but what kind of chains must drive that thing? : It would certainly make an interesting one make race series.
was extinct but got better.
Velociraptor is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 12:46 PM   #5
Steffo
LPG > You
Steffo's Avatar
Have they found someone with the balls to drive it yet? They were claiming it can go 300mph (480km/h).
LPG Lovers Association President & Member #1.
Steffo is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 12:48 PM   #6
Dave_au
That was out at the detriot motorshow last year
Dave_au is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 01:02 PM   #7
gozza
gozza's Avatar
how stupid
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 01:15 PM   #8
Casper
Contributing Member
Casper's Avatar
Originally Posted by gozza
how stupid
funny, that comment springs to my mind a lot when I see your posts.
Old 24-08-2005, 01:27 PM   #9
The Mighty Red
The Mighty Red's Avatar
Awesome and very radical piece of machinery,
Deffinately needs a set of Wheely Bars lol
The Mighty Red is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 01:56 PM   #10
TZENU
XY Driv3r
TZENU's Avatar
U can always rely on the Americans to build some crazy as bikes.... (OCC and WCC spring to mind!)
Nothin like american muscle between your legs :
Genuine Faker NOW BROKEN
Imagniation is a human element creativity is the result
TZENU is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 01:58 PM   #11
paul7v7
bring it on
paul7v7's Avatar
ugly as sin and does nothing for me, i am sure it would go ok but will it stop like the dodge viper?
Here is the devil-and-all to pay.
paul7v7 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 02:09 PM   #12
damo351
hmmmm wonder if you could fit that engine somhow into a laser.... LOL talk about a sleeper
Old 24-08-2005, 02:26 PM   #13
MITCHAY
Heres another crazy bike
http://www.bikez.com/bike/index.php?bike=20204
Apparently street legal too.
MITCHAY is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 02:32 PM   #14
pauljh74
pauljh74's Avatar
I've heard people call motorbike riders "temporary citizens". Bikes like these might just make these people even more temporary.
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 02:40 PM   #15
Velociraptor
Digging for avatar
Steffo, if given a chance I would ride that thing in a heartbeat and I would love to take you as pillion. :hihi:Youd have to sit on the guard though. :evil_laug
Old 24-08-2005, 02:44 PM   #16
Heeno
Formally knowen as EBus
Heeno's Avatar
lol what a beast, makes the hybossa look like a b!tch....hmmm does it come in dirtbike version?? :1syellow1
Car: :evilking: 91 EB Fairmont 3.9L :evilking:
Changes: 5 spd manual
Extractors, 2.5in exhaust
AMG Quake 17's w/ maxxis rubba
Lovelle superlows
Cheap a55 Pod Filter
Bike: CR250R 05 :evil3:
Heeno is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 03:07 PM   #17
XRated
Shoot.
XRated's Avatar
Dodge doesn't seem to like handling.. 20 inch brakes! LOL!
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 04:54 PM   #18
Ryan
WTF??? its a bike. lol
I was expecting some kind of new age muscle car. lol
Ryan is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 08:09 PM   #19
merlin
merlin's Avatar
nah its so BIG that car drivers might actually see it :
Old 25-08-2005, 11:24 AM   #20
andrew_smith_84
my one day build...
andrew_smith_84's Avatar
Originally Posted by VY18s
WTF??? its a bike.
i'm guessing it should be called a quike having 4 wheels. like to see a rider of 1 sneak their way to the front at a red light.
andrew_smith_84 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2005, 12:10 PM   #21
gozza
gozza's Avatar
i was talkin about the bike
even tho it was interesting to read i think its a stupid idea...that my opinion...
and wat u said is ur opinion...just a shame u have to get personal
Old 25-08-2005, 12:25 PM   #22
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
If anyone has ever started an engine up sitting on the ground, and blipped the throttle, you know that the instant you blipped the throttle on that thing, it'd wind up on its side.... and you'd need an engine hoist top lift the b*astard off your leg...
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
