Old 22-08-2005, 08:47 PM   #1
T_Terror
The Guy You Love To Hate
Default IRS into E-series
Was chatting to the bloke at FTG Salvage today about IRS conversions.
Thought it may be of interest, he mentioned that someone came in and bought an IRS rear end from an AU and did a conversion into his ED.
Apparently everything bolted in, only needed a space cut in the bottom of the boot to access hard to reach places for the cradle mounts when welding.
T_Terror is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 08:54 PM   #2
LUXO_8
windsor user
yep.....knew it already and the front end is fairly easy too aparently
gives AU offset too
i'd do it if i could afford
Old 22-08-2005, 08:56 PM   #3
EFFalcon
Last warning
EFFalcon's Avatar
FTG did it to an EB or ED XR8 from what i recall
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 22-08-2005, 10:43 PM   #4
NZ
NZ's Avatar
I got quotes 1200 for the IRS unit then when I asked again ready to buy it went to 1750!
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 10:46 PM   #5
Casper
Contributing Member
Casper's Avatar
Its not that hard, the AU used the same mounting points for the IRS and the live axle... which is very much the same deal as any E Series.
I can highly recommend it too. Yes its heavy but you can say goodbye to bump steer and the grip is superb!
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 10:48 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
i want an AU live axle rear end and AU II kframe & brakes
would suit me well!
Old 22-08-2005, 11:17 PM   #7
sphell
sphell's Avatar
would suit me well!
buy an AU then : :P
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 11:23 PM   #8
EFFalcon
Last warning
EFFalcon's Avatar
Originally Posted by sphell
buy an AU then : :P
says the man with an AU engine ;)
lol
Old 23-08-2005, 10:42 PM   #9
MrFlibbles
ill have a beer milkshake
MrFlibbles's Avatar
so the au front/subframe etc fits an ef?
current cars:
2001 AU SII XR6 manual
2001 Nissan Patrol
1969 Isuzu Florian
1976 Chev luv (really its just a rebadged Isuzu!)
1980 Isuzu KB 4x4
MrFlibbles is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 10:44 PM   #10
LUXO_8
windsor user
you aparently have to weld a couple of locating studs in, and then it does........aparently.
would love to try it
Old 23-08-2005, 10:44 PM   #11
EFFalcon
Last warning
EFFalcon's Avatar
its not a straight bolt up, there are some mods to be done.
but apparently it *can* be done.
Old 23-08-2005, 10:56 PM   #12
MrFlibbles
MrFlibbles's Avatar
anybody done it? and is the only benifit being able to use au/ba wheels, or are there other benifits?
current cars:
2001 Nissan Patrol
1969 Isuzu Florian
1980 Isuzu KB 4x4
Old 23-08-2005, 11:02 PM   #13
EFFalcon
Last warning
EFFalcon's Avatar
no one that we know has done it.
benefit = au/ba wheels & better brake upgrade options.
Old 24-08-2005, 08:34 AM   #14
EA2BA
PM me if you want
EA2BA's Avatar
AU have an alloy k-frame so would be lighter as well I belive.
Old 24-08-2005, 08:37 AM   #15
Racecraft
they call me Tibbo
Racecraft's Avatar
Yess but it is a heavy rigid bit of kit, I'd dare say the EF/EL hollow kframe would be lighter...
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 08:53 AM   #16
NZ
NZ's Avatar
The only thing close would be my friend who retro fitted an EB k frame into his AU ute.
He orginally raced an EB in offroad racing, he made his own suspension to suit (lengthened spindles, custom springs and shockers, big offroad tires etc) so when it came time that ford wanted him to upgrade to the AU instead of having to go and make everything again he simply just swapped it over. I've talked to him a fair bit about the conversion but not having any real knowledge about the 2 setup's it was hard to understand. He also beleived the steel k frame was a bit more durable. Looking at his photo's from the races I can say he would have wanted the strongest setup he could get! Quite a lot of his photo's involved the car being airborne and some of the stories he has told are quite amazing
Old 24-08-2005, 10:55 AM   #17
Rmyers
Does Steve have a car?
Rmyers's Avatar
Awww man, i'd love to do this, only thing is i spent a sh!te load to get my current diff modified, meaning that would have all gone to waste :( Ahh well I might consider it when i run outta things to do :P
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 10:59 AM   #18
Rmyers
Rmyers's Avatar
You wouldn't be able to get us some of these photos would ya?? I remember seeing a couple of photo's of a red rally stylez EB, prolly the same guy...
AKA Mr Silver
Old 24-08-2005, 11:01 AM   #19
Psycho Chicken
Psycho Chicken's Avatar
AU k-frame should bolt up pretty easy. As far as I can tell, you need to lengthen two studs, that's it, it uses the same mounting points. Upper arms bolt up, might have to use AU shocks. I was going to do it to fit the AU engine and AU2 brakes, but obviously that plan is over.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 05:37 PM   #20
Polyal
The 'Stihl' Man
Polyal's Avatar
So we need to engineer a turbo, but changing the complete suspension setup doesn't?
Seems like ALOT of stuffing around, surely a nice aftermarket kit (springs/shocks etc) could be done for much less than that and not be too far off.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Old 24-08-2005, 05:53 PM   #21
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Rough price for an EL GT brake conversion is $1200, and theres only so much shocks/springs can do to overcome different suspension designs/angles.
I'm seriously thinking about doing the AUII front conversion, I need to replace the K-frame, change radius rods, some bushes, sway bars etc, so its not a bad idea.
Does anyone have a few high-res pics from underneath an AUII? Do the PBR Cobra twin piston 330mm brakes bolt to the 298mm stock brake spindle, or are they different??
Old 24-08-2005, 06:33 PM   #22
MrFlibbles
MrFlibbles's Avatar
might try it on something too!
current cars:
2001 Nissan Patrol
1969 Isuzu Florian
1980 Isuzu KB 4x4
Old 24-08-2005, 06:37 PM   #23
Racecraft
they call me Tibbo
Racecraft's Avatar
but the AUII set-up is better than anything you can bolt on for under $3000
Old 24-08-2005, 07:04 PM   #24
LUXO_8
windsor user
yep thats the one steve....
Old 25-08-2005, 10:01 AM   #25
NZ
NZ's Avatar
Look in the technical section. Theres a detailed section on the AU suspension setup. Unsure is its AU1 or AU2.
Old 25-08-2005, 10:22 AM   #26
NZ
NZ's Avatar
I have emailed him. Maybe something better to do would be something for the website? Much like whats on trueblueford.com but more about his eb
Old 25-08-2005, 12:16 PM   #27
LG
LG's Avatar
Yup, the Premium Caliper bolts straight up to the stock AUII/III, given that you have the braket.
And the stock AUII/III brakes were 287mm by the way.
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2005, 04:35 PM   #28
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Cool, thanks for the info guys.
Will the brake booster/master cylinder need to be changed?
Here's the article for the front susp. It is AUII
http://www.fordforums.com.au/vbporta...article&id=158
