Old 08-01-2010, 11:22 AM   #1
mohit
mohit's Avatar
Default 60K Major Service
Had the 60K major service done yesterday to our 2006 LS Focus by my regular local mechanic.
Here's what was done:
- Oil + filter
- Platinum spark plugs
- Air filter
- Brake fluid
- Machine brake rotors
- Puncture repair and wheel balance
- Usual top up fluids, lubricate everything, etc.
- Labour
I paid just under $590 for this service. Is this is a good price?
The service hand book states the fuel filter needs to be changed but my mechanic could not find a changeable fuel filter on the car. He called up Ford and they said only LT models have an external changeable fuel filter. So i guess on the LS models it must be in the tank or part of the fuel pump.
mohit is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2010, 11:31 AM   #2
BrisVegas
Noobie
i had mine done a few months back but didn't need the brake rotors machined nor a puncture repair. Was $345.80 at Ultra Tune.
fwiw, I got the 75,000km service done at Ford (Denmac Ford, Darra) just in case there were any warranty issues and they charged $220. The prior 'minor' service I got at 45,000km at Ultra Tune was $168. The Ford service mob gave me a good price though as my car was still under lease and subject to fleet discount through SG Fleet. Apparently, the minor service was meant to be $300+ at retail pricing.
BrisVegas
WS Fiesta Zetec 3dr
NM Pajero TD LWB
LS Focus Zetec 5dr - gone
WS Fiesta Zetec 5dr - gone
BrisVegas is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2010, 11:53 AM   #3
mohit
mohit's Avatar
Yeh mine was done by Ultratune as well (in Bulleen). Only mechanic i trust which is why we've been taking all our cars there for the last 10 years. I guess the labour rate varies which will change the final price.
Old 09-01-2010, 11:16 PM   #4
NO2
Old Man
Machining brake rotors!!!!!!!!!!!!
I didn't think the rotors where machinable, the tolerances aren't there. The original rotors wear as quick as the pads. If you are a careful driver you will get 60k from them and replace with non genuine for about $300 odd if I remember or more if you are going for slotted. If you ain't careful you might get 30k. I would check if they were original rotors.
There are brake rotor threads on this forum to check out.
NO2 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2010, 10:41 AM   #5
mohit
mohit's Avatar
When we bought the car i looked at the rotors and pads and they did not look like the originals so they have been replaced in the past by someone.
Brakes were machined/lightly skimmed as they were glazed over and were squealing. Nothing wrong with doing that.
Old 10-01-2010, 08:57 PM   #6
casabonka
You can call me Chris
casabonka's Avatar
Thought I would just jump on the back of this thread - got my 45k service comnig up in a couple of weeks. Other than oil (filter wont need to be done) what else should I make sure they check/do? Are plugs to be changed at 45 or 60k?
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2010, 01:14 PM   #7
somers181
somers181's Avatar
Just had my 60,000 (major) service done by Ford and was charged $801.05
This breaks down to Labour: Service $201.60, Brake Fluid Flush $57.60, Throttle Body Service $65.00. Parts: $292.18. Lubricants: $92.87. Misc: $18.98. Tax: $72.82
The reason i go to Ford is for the things the local mechanic doesnt get told, e.g. At this visit i was told of Ford Recall P0705 (Wheel house Liner Modification) for LS Focus and this was completed at no cost under Ford Warranty. Previously there was a brake issue at 42,000kms which i had Ford fix under warranty. It appears these issues are only fixed when you take your Focus back to Ford as there is nothing sent to owners in writing unless its life threatening????????
Capri Car Club of NSW,
Keeping the Legend Alive since 1985
somers181 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2010, 02:34 PM   #8
DZFord
DZFord's Avatar
I'm about to try these guys for the first time, I'm glad you approve!
Old 31-01-2010, 09:29 PM   #9
jarradgoodwin91
going to get my 06 focus ls serviced by windsor toyota tomorrow!
i only bought the car 6 months ago with 37000 on the clock
they signed for the 45000 service so now its going in for just a general service.
ive only got 44000 on the clock.
they reckon about 220 or 230 dollars for this
also gotta get the a/c checked out!
stopped working other week!
its a mechanical problem, so if it isnt covered under the 3 year dealership warranty that i have ill no longer go back to them for my services.
i also informed them that if its not covered i want them to contact me before they try any repairs, and to give me a quote to fix it.
and if thats the case ill take it to a car air con joint and get a second opinion
but hopefully it doesnt come to that.
jarradgoodwin91 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2010, 09:03 PM   #10
GAL
I had a 60K service on my 2003 LX last week at Ultratune and it cost $440.00 set price.
Today had water pump replaced $430.00, this appears to be pretty expensive but will follow up tomorrow.
GAL is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2010, 04:30 PM   #11
jarradgoodwin91
took my car for service on monday,
apparently needed new front brakes!
and being a toyota dealership, it sent my service bill up 200 bucks!
grr
oh well
they said they'll fix my air con under warranty
turns out the compressor clutch is stuffed
now just waiting on a phone call to say they have the part so they can book me in!
such a pain having to drive out there to do the service!
Old 02-02-2010, 04:45 PM   #12
casabonka
casabonka's Avatar
Have you got a price on a different set of pads? Apparently the stock rotors are very soft. For a few bucks extra you might be able to get dba's or something better?
mines goes in on sat for its 45k service which im waiting for the call.. umm sir, your brakes are screwed....
'06 LS Focus Hatch
-Tinted Windows
Old 04-02-2010, 10:09 PM   #13
DZFord
DZFord's Avatar
Got my major service done at Ultratune today as well. Paid $536, it included the sparks, oil + filter, brake fluid, balance and rotate tyres and wheel alignment (left front tyre was wearing out faster than the right; slight steering wheel wobble at freeway speeds).
Overall I was happy with the service, except for when they told me the timing belt was due soon, which isn't actually due until 240,000km.
Old 05-02-2010, 09:07 AM   #14
Conquest_Tsi
Arnt't most timing belts due to be done every 100k?
Conquest_Tsi is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2010, 12:33 PM   #15
mohit
mohit's Avatar
Yes but the LS/LT/LV Focus with the 2.0L petrol engine have a timing chain that needs to be replaced every 240,000km
Old 05-02-2010, 12:36 PM   #16
DZFord
DZFord's Avatar
I always thought that too, ie. 100,000km, until I checked the manual which says exactly that - 240,000km or every 10 years.
Old 05-02-2010, 01:40 PM   #17
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
Hey Mohit, my car is booked in for its 60k service on the 13th. so i'll let you know how it campares.
i'll be asking them to replace the wipers / battery and possibly hatch struts as well. :S
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2010, 02:42 PM   #18
smee323
Yes it is mine...
smee323's Avatar
60k service on the ST this weekend.
$483 quoted, plus charge for a brake flush.
Will see what they come back with in regards work needed if anything.
I did pads and rotors 5000 k ago along with tyres, so no need for anything there.
smee323 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2010, 04:41 PM   #19
casabonka
casabonka's Avatar
Eeep - Feb is obviously the month for Services.
Mines quoted as $250.... to change the oil and have a look over it.
Going to make them look over everything though to get my money's worth. I have an annoying creak in the back (my loose spare wheel thread) Which I got the missing part, but its either in the tailgate or somewhere.
On a side note, Ive done 45k now, but the owner before has had the 45k service done already. They wont need to do the 'b' service will they?
'06 LS Focus Hatch
-Tinted Windows
Old 05-02-2010, 05:43 PM   #20
marg99
I do not do many Klms so they do the "cheap" serviceeach year, and simply stamp the next scheduled KLM service on the booklet, so no guarrantee you will escape the big dollar service Watch for the new brake rotars.
Old 05-02-2010, 09:01 PM   #21
20focus05
I wanna XR5
20focus05's Avatar
$%&# I might start doing home jobs
They know how to charge
$65 for a throttle body service. LOL shameful
I am a mechanic so I guess I miss out on paying the inflated prices.
As for timing belt on the LS onwards its a timing chain so 240k
I changed all my rotors to dba slotted at 45k
I got 98k out of the front brakes but the rears about 50 odd
am at 152k now and the front brakes are at about 70%
I do have a manual and use the gears to assist with braking.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2010, 09:04 PM   #22
casabonka
casabonka's Avatar
Incase I do get the bad news tomorrow, how much are the DBA's?
'06 LS Focus Hatch
-Tinted Windows
Old 06-02-2010, 07:38 PM   #23
casabonka
casabonka's Avatar
Well got my 45k service done. $180 for oil, check over brakes, lubricate locks and check steering and all fluids. Front rotors have about 8k left on them. Had the service done through subaru and was very happy with their service, and only took just over an hour!
'06 LS Focus Hatch
-Tinted Windows
Old 06-02-2010, 11:22 PM   #24
smee323
Yes it is mine...
smee323's Avatar
Took ST170 in for 60k service, came out with a 2010 plated Colorado Red XR5.
Do not know how that happened.
Old 06-02-2010, 11:56 PM   #25
mohit
mohit's Avatar
Hope they didn't make you pay for the service after all :
Old 10-02-2010, 07:46 AM   #26
vik351
vik351's Avatar
My brakes started to squeal,30 odd K,city driving only,and that was the problem.My bloke said get on the open road,do three of four hard stops from 110 kph to get some heat in the pads...
Did this and no probs,not a squeal to be heard...
vik...06 LS CL auto
vik351 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2010, 01:16 PM   #27
DragonMesh
hmm i've got my 45k service coming up 2000km ago. I've always taken my car to Wayne Phillis Ford in adelaide.
Now my car is out of warranty and i've ordered in new DBA slotted rotors and EBC greenstuff pads, also going to get some Mobil 1 oil too. Any ideas if the ford dealer will get ****y if i turn up for the service with my own parts mentioned? They have always given great service before.
Or do you guys recommend me going to somewhere like ultratune?
DragonMesh is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2010, 01:54 PM   #28
mohit
mohit's Avatar
vik...06 LS CL auto
In my personal experience this causes rotor warp
Old 13-02-2010, 12:00 PM   #29
Velociraptor82
Eat my Brake Dust
OK just back form the 60k service at Strapp Ford and here are the results:
Labour 202.40
Parts 234.38
POL 67.43
Misc 5.02
Tax 50.92
Total 560.15
Inc: Spark Plugs, Air Cleaner, Oil Filter, Semi Synthetic Oil, Injector cleaner, Coolant & wiper blades.
This doesn't include the battery or hatch struts as mentioned in my earlier post. FYI Hatch struts are $360 each.
Old 13-02-2010, 12:17 PM   #30
mohit
mohit's Avatar
Hahaha what a joke. Better off getting your struts reco'd or getting a set from a wrecked Focus.
