Old 22-02-2010, 02:55 PM   #1
Ecortboy01
Default Escort Cortina 2l Cam's
Hey All Just after some advice on with cam Is best for a worked 2l pinto motor as the lob or something like that has went and is making a really bad ticking noise, it is a RC race build witch i brought not along ago and did the cam in it and dunno witch cam i should go with would love some help
Cheer's Jarred
Ecortboy01 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2010, 03:40 PM   #2
V8falcons
V8falcons's Avatar
A great cam for a 2ltr pinto , is A"crow 661", use with extractors,exhaust, free flowing air filter,and dyno tune and a rejetting of the stock weber for good results.
nice lumpy idle as well.
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2010, 03:53 PM   #3
Puzzlescort
Rally Nut
Puzzlescort's Avatar
Escortboy
what carburation are you using?
Does it have a lot of head work, ie porting, big valves?
Compression ratio?
what are you planning to do with the car?
All of these factors & more need to be considered when choosing a new camshaft
there are so many cams available for the pinto from the UK & even here its nearly a loaded question with out more information
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2010, 03:59 PM   #4
Puzzlescort
Rally Nut
try these Escort (small ford) sites
http://classicford.mine.nu/forum/top...TOPIC_ID=17737
http://www.rsmotorsport.com.au/forum...opic.php?t=858
cheers
Old 22-02-2010, 03:59 PM   #5
Ecortboy01
Cheer's mate, are they idel for really worked as the motor has had alot of bottem end work running sidedrafts,msd ignition multiple spark discharge and hopefullying running a small supercharger soon, i like the sound of a crow 661 for the lumpy sounding, SO pretty much been built top to bottem cheers
Old 22-02-2010, 05:22 PM   #6
rag top
rag top's Avatar
when you replace the cam, also replace the oil spray bar at the same time. I always found it to be cheap insurance to increase the life of the cam as it is a pain in the butt to replace.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
