Old 08-05-2010, 04:44 PM   #1
danscort
danscort's Avatar
Unhappy Heater problem
Hi,
Can someone help me as I have never worked on a heater box before and I have searched the site but can't work out my problem.My Mk1 escort started leaking coolant from the heater box so I took It to Pt Adelaide radiators. Cost of new was $250-$300, so fixed the old one $45
Put It back in with the water pump hose and inlet manifold hose going into heater box with no shut-off valve - no heat (engine hot). Rang Sprints, they said you need the valve on hose from water pump to inlet? (top fitting at heater box) Did that - NO HEAT
danscort is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2010, 12:45 PM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
Escorts didnt have an external valve from the heater box.......did you connect all the control wires back up to the heater controls or are they working?
follow the control cable and see if they are still connected inside the heater box
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2010, 10:39 PM   #3
danscort
danscort's Avatar
Thanks Puzzlescort but I worked It out, wires are all hooked right, Heat coming from de-misters and floor (I was only checking dash vents first, which is cool air only)
Old 11-05-2010, 10:52 PM   #4
danscort
danscort's Avatar
Sorry didn't mention my Mk1 has a Mk2 dash.
