I've managed to crack the rocker cover on my EA Wagon (3.9 CFI). Ford don't make the part any more, so it looks like I need to get one from a wrecker.
Do you know of any later models with the same shape rocker cover, or am I restricted to only getting a replacement from an EA? I'd like to get a newer one if I can, maybe a different colour to the broken silver one I have got now....I've seen red and blue covers, what do they come off? |
hibernating
You can fit ea to ed without any problems. ef and el you can also fit but it has a different gasket and may leak a bit around the half moon shapes
Red covers came on XR6 models, blue covers have most likely been painted by people. Like me. I have an EF rocker cover on my EA, painted blue.
EF-EL rocker covers fit no problem, just put a bit of silicon in the half moons before you bolt it on. |
What model followed the EA? You mentioned 3 models, the EL, ED and EF, which is the youngest car? I don't know in which order the cars were released after the EA.
Do you know if I will be able to pick up a new rocker cover for any of the above models, or will it be a scrap yard job? Thanks |
EA, EB, ED, EF, EL
You'll probably still be able to get an ED or EF cover new - but it'll be expensive. They are usually about $20 from self serve wreckers. |
Hmmmmm
what is the sort of paint you would use to colour a rocker cover?
Posts: n/a
Hi-temp engine and brake caliper paint. BTW how did you manage to crack the rocker cover
#8 | |||
PM me if you want
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
Factory EBII and ED rocker covers were blue.
Thanks for the replies....
Yeah I stupidly overtighted the nuts on the rocker cover...as I did the thing made a loud cracking sound, more like a pop actually...I've now got an oil leak coming from the cover. I'm going to have to check now to see if I've damaged a pedastal mount point like you said. If I have managed to damage one, how can that be fixed? Where do they fix to? Are they on the cylinder head? |
#11 | |||
No longer driving a Ford.
Where are you mate? We've got a rocker cover here that LuvinmyEB might be willing to sell cheap if you want it...
#12 | ||
Northern Beaches Sydney...I will go to the wreckers this weekend to see what I can pick up.
So does anyone know where the pedistal mounts are fixed? Cylinder head? engine block? Cam Assembley? |
#13 | ||
Does Steve have a car?
Pedestal mounts are part of the rocker assembly and bolt to the top of the cylinder head. You will need to unbolt the entire rocker assembly to change a pedestal (i think it's about 24 bolts or so)...
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
#14 | ||
PM me if you want
I thought 28 for the rocker gear
#15 | ||
Hmmmmm
if you take the rocker cover off, do you need a new gasket or silicone for when you want to put it back on?
#16 | ||
28 bolts - each one needing to be tightened at least twice.
Juz Gremlin - depends on what condition your old gasket is in. If your old one is hard or brittle, ditch it and get a new one. ED if you are fitting EA-ED rocker cover, EF if you are fitting EF or EL rocker cover. EF gasket is a funky silicon-y type of gasket, that sits inside a rim of the rocker cover. With ef, you will also need some silicon in each half moon - else you will get leaks. |
#17 | ||
Hmmmmm
noice, thanks mate
where can i pick one up from.....just at a Ford dealer, or a repco etc? |
#18 | ||
you can pick gaskets up for the rocker cover from any reputable spare parts place
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
