Old 20-09-2005, 10:04 PM   #1
spope
spope's Avatar
Default Pinout info for EB2 Smartlock controller?
Before I go nuts and write one up myself, does anyone have a list of pinouts for the Smartlock controller and/or EB2 Fairy BEM?
I'm kinda hoping so - otherwise I'll be using the manual and writing it out myself.
A pinout listing is a lot easier to work with than a Ford wiring diagram.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2005, 12:01 AM   #2
CruizinEB
would that info be in the workshop manual?, if so i will find out a TAFE
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2005, 08:51 AM   #3
spope
spope's Avatar
You don't really read what people post, do you?
I have the manual. I was hoping someone had translated it into a pinout listing, ala what you find on fordmods.
I'm making one up myself, now.
Thanks anyway.
Old 21-09-2005, 09:45 AM   #4
NZ
NZ's Avatar
All I did was just lable the loom wires as I went. Its easy as
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2005, 10:21 AM   #5
spope
spope's Avatar
That's the other option too.Yours just worked, didn't it Karl? Did you get a remote coded up as well?
Old 21-09-2005, 10:39 AM   #6
NZ
NZ's Avatar
All I did was just started at the plug extract each wire at a time till it gets to a plug. Look up the wire, what it does work out if you need to go further or not. A couple need you to get the terminal plus the next one from memory the yellow wire went to the boot switch then bridged to somewhere else? some like the constant power from the coutosy lamp circuit just hook into the circuit with these lieelt brass clamps. you just cut them off there and hook it back to the same loom as the same place. At the end your donor dash loom will be a pile of wire and tou'll have a plug woth about 14 wires hanging from it. You'll see how spartlock was an addon as well.
Mine worked first pop. I haven't hooked up the door wiring and my smartlock jewel sits behind the dash somewhere. The door wiring is just 2 wires to hook up but yeah its pretty easy once you get going.
http://www.fordforums.com.au/showthr...140#post329140
By the end your dash loom will be a pile of wire and you'll have a
Old 21-09-2005, 11:25 AM   #7
spope
spope's Avatar
Yeah, I've stripped a loom apart before to get wiring for climate.
I already noticed in the manual that most of the wires just hook into existing circuits.
They just laid it over the existing loom when they designed it, pretty clearly.
Should be fairly straightforward.
Old 21-09-2005, 10:02 PM   #8
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
here you go mate i think the info u need is here.... http://www.fordmods.com/forums/documents.php?doc=41
174rwkW N/A I6 Kurucu Performance Enhanced...
Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph
Now With EL XR6 Engine & ECU & 3.7 Gears
Www.KurucuPerformance.Vze.Com
QUIKXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2005, 10:05 PM   #9
spope
spope's Avatar
Thanks for that, but not quite what I'm after - that's the pinouts for the ecu. I need em for the smartlock module.
Old 21-09-2005, 11:08 PM   #10
spope
spope's Avatar
This is what I was after - just knocked it up then. Easier to work with when your head is under the dashboard
Old 21-09-2005, 11:27 PM   #11
CruizinEB
i carn't open it,Why?
Old 21-09-2005, 11:30 PM   #12
InitialD
Low and Loud
InitialD's Avatar
How are we suppose to know? its a Excel file.. Do you have excel? do you have Micorsoft office? :
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2005, 11:34 PM   #13
spope
spope's Avatar
Because it has a built in spell checker.
It's in Excel 2000 format - and I can't be bothered saving it to an earlier format right now. I'll re-jig it tomorrow and turn it into a html document.
Old 21-09-2005, 11:45 PM   #14
NZ
NZ's Avatar
www.fordmods.com
www.fordaustraliaforums.com
www.fordforums.com
www.iqtest.com.au
Those sites will keep you busy. especially the last one.
