Unlock the Digital Dash on Fords
UNLOCK YOUR FORD LCD DASH DISPLAY FOCUS PUMA FEISTA Details Self Diagnostics Mode The Self Diagnostics Mode gives you in-depth information about your engine and the actual numbers in digital. To use it, follow the steps: * Insert Key but do not turn it on * Press and hold the Trip Meter Reset Button * While holding the reset button, start your car and continue holding the button * Within 10 seconds, the display should change to "test" in LCD font and the needles will do a full sweeping. Release the Button Pressing the button will now cycle through some 17 different modes * 1.Shows a Gauge Sweep * 2. Shows all 8's on the LCD (LCD TEST) * 3. Illuminates all the bulbs on the dash * 4. Displays hexadecimal value for ROM level * 5. Displays the hexadecimal value for EE level * 6. Shows DTC (Diagnostic Trouble Code) * 7. Digital Speedometer - mph * 8. Digital Speedometer - kph * 9. N/A * 10. Digital tachometer * 11.Fuel volume * 12. Engine coolant temperature * 13. Battery voltage * 14. ABS fail * 15. Electronic brake distribution (EBD) failure * 16. Illumination * 17. Crank Sense
Awww Mannn, soon as i fix one thing another thing dies ![]() .................................................. ............ Hers - 2006 Ralliart colt :newangel: Mine - 2004 Fiesta zetec turbo :gren: .................................................. ............ |
AFF Post NAZI
dont waste your money
just hold down your button on the dash b4 you turn the ignition to start the car. some one else ie (zetec) will give you the FULL rundown on it
Non-Regular Member
Where did he mention money sean? He also gave a full rundown in the post
AFF Post NAZI
no idea......
normally they are ebay thingys..... i suppose im starting to categorise threads now :P i dont know. Shhh just leave me alone :P
lol'
damn it should of done a little more reserch B4 buying a diagnostic hand controller for my Fez.......Damn software gremlins !!!
hey guys does anyone have a list with what the trouble codes are, i need it asap, thanks.
Lil Henry
Does any one know what the warning light of a fuel pump with like 3 raindrops means?
#8 | |||
Where to next??
Lil Henry
ah ok wasn't sure i have never seen it lit up but i wanted to know what it meant cos the manual does not say, i thought it might of been when you have an accident and the fuel line is cut off.
#10 | |||
sorry for being a noob lol but whats the website? ive tried www.bluefin.com.au and www.bluefin.com and nothing comes up? could you please help me out with the site, thanks.
is it www.mybluefin.co.uk? every code ive tried to enter says its not a right code, reowww so frustrated lol.
#13 | ||
http://www.mybluefin.co.uk/helpdesk
That's the URL ![]() If that doesn't work, maybe it's time for a visit to Ford? |
