Old 03-11-2010, 07:02 PM   #1
russellw
Chairman & Administrator
russellw's Avatar
Default Ford Engineers Listen To The Science Of Sound
FORD is tapping into Generation Y to help discover the sounds of tomorrow.
The youth generation is just one demographic the company is researching to develop in-car alerts and warning chimes to help drivers respond to possible dangers.
Ford's research work in the United States into the science of sound shows certain types of alerts work better in certain situations and that sound frequencies and rhythms play an important role in the driver responding appropriately.
Any in-car alerts and sounds must also appeal to drivers of different ages in the various Ford markets across the globe.
"Ford engineers spend a tremendous amount of time finding just the right sound for just the right situation to help customers react to potential dangers," said Paul Mascarenas, Ford Vice President of Engineering, Global Product Development.
"We also listen to our customers so they listen to the car when needed – we don't want them to be annoyed and tune out important warnings."
The company has work shopped a wide array of sounds such as a golf ball rattling into a cup, bird and insect noises and youthful club music like the "Youth Scratch" sound created in the likeness of a DJ scratching a vinyl record – many of which do not make the final cut.
Some sounds that were considered but not adopted, such as the sound that mimicked the chirping of crickets, were too literal to be effective.
Other sounds that do well in consumer preference testing do not meet the standard for eliciting the proper driver response, such as the soft, electronic beat sound "Techno01", similar to club music around the world. "Techno01" did well in the subjective studies but was not audible enough to cut through the car’s background sounds.
Others couldn't overcome a generational divide, such as the "Youth Scratch" sound so loved by Generation Y. Ford discovered that it appealed to younger drivers, but not to older drivers.
Finding the right universal sound that works for all drivers is a challenging objective and one that transcends geographic boundaries.
"Ford has an extensive process for developing sounds just as a conductor brings together different instruments to make a single sound," said Alex Petniunas, technical expert for Sound Quality.
"But the goal of our sounds is not to entertain you; it's to help make sure you respond quickly to the driving environment that can change instantly."
Because sensory perception and preferences vary around the globe, Ford also tests some sounds in different regions to develop uniform cues that work in specific consumer markets.
For example, 24 sounds options were tested for a new global turn signal chime for Europe, North America, South America and Asia.
By leveraging the company's global resources, sound engineers were able to determine in a week the new variation of a modern-day version of the "tick-tock" customers have grown accustomed to based on older electro-mechanical systems that relay the beating sound of their turn signal.
"There are both creative and technical elements in fine-tuning our sounds to get them exactly right," said Petniunas. "A key objective is identifying the kinds of warnings drivers will find both more effective and easier to understand so that safety features are used correctly and more frequently."
A team of Ford engineers spend their days dreaming up sounds and subjecting them to a battery of tests to determine which warnings help drivers best react to possible dangers and work in harmony with other sounds in the vehicle.
This gruelling process involves complex scientific theory, listening clinics and on-road simulations to whittle down numerous sounds to the few that prove most effective.
In developing its safety sound cues, Ford relies on principles of music theory, mathematical analysis and psychoacoustics – the study of sound perception – to research properties such as pleasantness, loudness and sharpness.
As a musical composer might select from different types of sound to cast a specific mood, Ford sound technicians choose from a palette of psychoacoustic parameters to create the ideal acoustical and vibrational environment based on the following measures:
The sights and sounds of Ford safety
Sight and sound alerts are incorporated into many of Ford’s innovative safety features, including:
BLIS® (Blind Spot Information System) with cross-traffic alert: Identifies when a vehicle enters the defined blind spot zone and illuminates an indicator light on the corresponding exterior rear view mirror, providing a warning that a vehicle is approaching. An audible alert is sounded as well.
Collision warning with brake support: This technology is designed to help drivers avoid rear-end collisions. Using long-range radar hidden in the front of the vehicle, collision warning detects moving vehicles ahead and alerts the driver of a collision risk with an alarm and warning light.
MyKey®: Allows parents to limit vehicle’s top speed and radio volume to encourage teens to drive more safely and improve fuel efficiency. The audio controls are important to maintaining a volume level that ensures drivers can hear outside warnings, such as emergency response vehicles and traffic hazard signals. It also encourages seat belt use, provides earlier low-fuel warnings and can be programmed to sound chimes at 72km/h (45mph), 88.5 km/h (55 mph) or 105 km/h (65 mph).
Belt-Minder®: A seat belt reminder technology for the front occupants that takes over after the initial seat belt reminder stops chiming. If the occupants remain unbuckled, the system chimes and flashes a warning lamp periodically for five minutes, or until the driver buckles up, whichever comes first.
Source: Ford Media
Observatio Facta Rotae
Old 03-11-2010, 07:20 PM   #2
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Interesting info there, kinda like the new GT which chimes when the RPM'S are in the red zone ...........
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 11:15 AM   #3
Quicksand
Lucky, lucky bastard!
Quicksand's Avatar
Very interesting. It would be good for them to tap into their likes/dislikes for entertainment/electronic/audio features of the cars. While they are speaking to them, they may as well find out what features Gen Y like in a car.
2015 Mondeo Trend 2.0T Diesel, Deep Impact Blue
2012 FPV GT-P 6spd Auto, Lightning Strike
Quicksand is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 12:52 PM   #4
flappist
The project has been abandoned as it took longer than 5 seconds and generation Y have already lost interest in it and are googling iPhone 5 vs Playstation 4 OMG LOL.
Ok now they have lost interest in that too........
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 01:18 PM   #5
ltd
Force Fed Fords
ltd's Avatar
To get Gen Y's attention just make every chime sound like a mobile phone when an sms is received. That'll get the little buggers attention; but only briefly as flappist said.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 01:30 PM   #6
fou_bleu
Get EcoBoosted
fou_bleu's Avatar
*sigh... the humor of gen y prejudice has got quite old tbh...
fou_bleu is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 02:28 PM   #7
vibe_xr6
vibe_xr6's Avatar
lol, i hate being in generation Y
Completely Stock
vibe_xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 03:15 PM   #8
TheInterceptor
Cruising...
TheInterceptor's Avatar
lol omg me 2
Seriously
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 04:12 PM   #9
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
Forget generation X Y Z. Target the primeval parts of our brains.
I'm sure I have read of similar studies done by the US airforce who found that the best sound to get a pilots attention is a Lion's roar (also stands the hairs on the back of their neck to attention, possible pants wetting and gets the adrenaline pumping). That old survival instinct is still there in all of us.
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 05:45 PM   #10
vibe_xr6
vibe_xr6's Avatar
lol that would be good, if you dont put your seat belt on you have a lion roaring, the beeping noise is good enough reason for me
Completely Stock
Old 04-11-2010, 06:02 PM   #11
duaned
duaned's Avatar
Yeah, and if you can hear those chimes with the bent 8 is a full song, then Ford haven't made the exhaust loud enough!
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2010, 06:19 PM   #12
RAREV8
Previously ScottishXC
RAREV8's Avatar
I'm sure the "lions roar" would have the red team laughing out loud at scared Ford owners
Great transactions with the following members:
BJ
Gilesie
XAGTCoupe
Pilch
Aussie_afroman
Donut King
Bad Boy Benny
BAWITHLOT
Greenmachine
Pinkbits
CUZ351
OhioXB
Falconunbelievable
4VXC
Uncleraggy
FG G6 Ego, tech pack, Tropic gold 1973 Landau, Cosmic blue 1975 P5 LTD....long term project
Originally Posted by 4Vman
Im just bored of the single/narrow minded...
RAREV8 is offline   Reply With Quote Multi-Quote with this Post
