Old 19-10-2010, 01:13 PM   #1
FESTEC
FESTEC's Avatar
Default Engine Mounts
Ok so there has been a couple of threads about Engine mounts on a mk2 focus, but I am wondering how you can tell if you have a faulty one and what the effects are on the performance of the car, either handeling or out right performance..
Festec
2006 LS Zetec Hatch Pure Silver
K&N Panel Filter, Lower Airbox Removed
RDA Slotted Rotors Front / Rear
RDA Extreme pads Front / Rear
18" GMAX Defiants with 225/45/18 Falken Tyres
Pedders Coilovers with whiteline rear camber kit
FESTEC is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2010, 02:16 PM   #2
rand0mn00b
well, you will know because the driving experience is seriously messed up
eg. when you accelerate the engine moves a bit before the power goes to the wheels and the opposite when braking. that is if they're broken.
if it's a mount that is starting to crack or become loose then the symptoms may be there but to a lesser degree but excessive vibration when revving etc
our cars don't have that much power but cars with torque like the XR5 or diesel might be more prone to it. i know that with the mazda MPS (which is similar to the focus in many ways) broken engine mounts are a very common problem
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2010, 04:09 PM   #3
FESTEC
FESTEC's Avatar
Is there and real way of telling, like some sort of test I can do, the reason why I am asking is because sometimes when I take off there is a creeking noise and the same when I come of the gas, but its not all the time and mainly at low speeds. It's not very loud so it may do it more than I think and or can hear.
Adrian
Old 19-10-2010, 05:32 PM   #4
casabonka
You can call me Chris
casabonka's Avatar
by the sound of ur description, it sounds the same as when mine broke. I had my mechanic check though as I was hoping it was under warranty. quiet an expensive bit to replace, cost me about $350 iirc
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2010, 10:59 PM   #5
DZFord
DZFord's Avatar
Casa, which one actually broke?
Festec, I have the same issue as you. Haven't really worried about it too much...always thought it was an engine mount or one of the CVs on the way out.
Old 20-10-2010, 12:29 AM   #6
Mad_Aussie
what-tut-tut-tut
Mad_Aussie's Avatar
Do any companies do race/performance quality mounts?
Mad_Aussie is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2010, 06:05 AM   #7
casabonka
casabonka's Avatar
@dz I think it was the bottom/rear mount. as u said though it could also be a driveshaft :$
'06 LS Focus Hatch
-Tinted Windows
Old 20-10-2010, 10:56 AM   #8
FESTEC
FESTEC's Avatar
Ok could a faulty engine mount affect the way the car handles as well????
The reason why I am asking is I am having a issue with the handeling, its a weird feeling that when you throw the car side to side it's like the car handles it but the engine or something is moving and makes the car all unsetteled, As I said it's really hard to explain..... I know it's not the suspension as that is all new...
Old 20-10-2010, 01:29 PM   #9
rand0mn00b
yes, handling can be affected as well steering may become sloppy and have delayed response
Old 20-10-2010, 01:31 PM   #10
FESTEC
FESTEC's Avatar
sounds like time to get them checked
Old 30-10-2010, 10:27 PM   #11
20focus05
I wanna XR5
20focus05's Avatar
One way to check is to have foot on brake and load up engine in forward and reverse gears and take note of what the engine does, may need someone else to do it while you watch or vice versa. engine will move more than usuall. harder to tell with the ones at either end on engine/trans but you can get i light and look for signs of cracking in the rubber. This can be done while engine is loaded up.
with an auto it may clunk on gear changes, manual too but you feed power on softer in a manual(between shifts are longer).
Bit of a ramble I know!!!
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2010, 11:16 AM   #12
FESTEC
FESTEC's Avatar
Ok update,
Took the car to Ford and guess what they are F'ing useless, apparently could not hear a thing (ie the creaking) and apparently the car handles perfect to them, yea right and then they slugged me $120....
Now the car has started do something even more unusal, at spped on the motor way it feels like it is rocking from side to side its like its wobbeling, it's very very loose, any ideas on what this may be??????
Old 02-11-2010, 01:48 PM   #13
DZFord
DZFord's Avatar
I'd either go to Pedders for a 28 point check, or put it in to an independent mechanic to check the engine mounts.
Old 02-11-2010, 05:19 PM   #14
FESTEC
FESTEC's Avatar
Yea was going to take it to my local mechanic and get him to check it out,
also does any know if seized wheel bearing could cause this????, I have checked them and they seem fine but I am just trying to think of things that I can get him to check
Old 08-11-2010, 08:31 PM   #15
jarradgoodwin91
hey mate, you come to any conclusions as to the sound ur hearing?
im having similar sounds, have been for a few months, asked the dealership (wintoy) where i bought the car from to check it out but they also claimed they couldnt hear anything.
jarradgoodwin91 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2010, 05:54 PM   #16
20focus05
I wanna XR5
20focus05's Avatar
whats the creaking noise? how and when does it happen
engine mounts dont usually creak, more of a thump on gear changes. handling not usually effected.
creaking can sometimes be heard during parking? had this once was drive shafts moving in hub, the fix was loctite drive shafts in hub(dealer fix).
have you had the ball joints looked at if the go dry they will creak, also the sway bar links as to the tie rod ends.
one way to find it is to put small hole in boot(joint boot) and spray CRC with tube into joint, do one at a time.
These are things that can effect handling.
