Old 01-10-2005, 10:28 PM   #1
Mr_tickFORD
Posts: n/a
Angry PLEEZE HELP!!!!! Engine Troubles
Hey guys,
my name is josh and i own a 1991 EA series 2 falcon and hav been having a bit of trouble lately with my belovered blue oval. The car has been stalling, both driving and sitting at the lights. When u try to start the car after stalling, it wont start staright away and u have to leave the car a while bfor trying to start the car again and it will start. the car is also delaying for like half secnd from take off. I dont know wat the cause is. Ive just put in a new pod filter, spark plugs are only 6 months old, the car is hardly driven hard, i run it on BP ultimate (98 ron), the throttle body and injectors hav recently been cleaned and a new started motor has been put in about 6 months ago. U MUST HELP ME!!! im so so so tempted to buy a new car bcoz of this problem, its that annoying and embarrasing. i was thinking the problem is either the air fule ratio, spark plugs, fuel filter or ecu problems.
A relpy by anyone would b awesome,
email me on fordfan_josh27@hotmail.com or just reply to the thread,
cheers boys
Josh
Old 01-10-2005, 10:32 PM   #2
Valknutr
Valknutr's Avatar
ok this car used to stall at the lights we got the MAP sensor changed and it fixed it right up, no idea on everything else though.
Oh and man there is alot of Joshes driving EAs around this place
car that goes (just) <----- gonna be MENACE so :thebirds:
Valknutr is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 12:14 AM   #3
Biggoggs
Rider on the storm
Is it an auto or manual? As Valknutr said above, could be the MAP sensor. Might also be the idle motor and could need a general tune-up. If all else fails, you could go see a mechanic that knows his stuff, it'd be cheaper than buying a new car.
Biggoggs is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 11:41 AM   #4
ilsautomotive
Former E-Series Member
I have heard of this happening, often it is related to the fuel pump from memory.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 12:05 PM   #5
Sprint_ED
Sprint_ED's Avatar
i had this also happen, it was my electronic egnition thngy that sits on the distributor
RIDE: Cobalt blue XR8 Sprint
MODS:Lowered, Paceys, Twin 2.25'' Exhaust By Hallam Exhaust, AFR 165's, Crane 2031 Cam, E-Series Edit, 180 RWKW
TUNED BY BLUEPOWER RACING DEVELOPMENTS 13.79 @ 102 Mph
Sprint_ED is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 08:26 PM   #6
vegabass
BASS ON BOARD!
vegabass's Avatar
That is embarssing It happened to me on the start line of the 1/4 mile!!!
For mechanic said the symptoms point to the fuel pump, dizzy, or broken (or loose) oxygen sensor. as all have same symptoms.
My car hasnt done it since.
Try useing a lower RON petrol see if that makes a difference.
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 08:29 PM   #7
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
TFI module
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 08:30 PM   #8
rev
Old but happy
rev's Avatar
maybe fuel pump but my guess is distributor cap/rotor.
rev is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 10:01 PM   #9
KUZMIN
Ruski
KUZMIN's Avatar
My old boss told me that is a common problem with the EA-EB-ED fords...said usually coil or dizzy from memory.
Alex.
R.I.P. 18-02-06
1997 Nissan Maxima 3.0 S. Touring-very quick!
KUZMIN is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2005, 10:03 PM   #10
mcflux
mcflux's Avatar
check the fuel pump relay too, that was the culprit in my car.
