Old 19-11-2010, 11:27 AM   #1
newi
Default Fiesta burning Oil - Common Fault?
Hey guys,
My Mum has a 2010 Fiesta manual and it seems to have developed an appetite for oil.
It had its first 3000k check at which my old man requested that the dealer change the oil (he's a bit old school when it comes to running in). They checked the oil at about 10,000k and it wasn't even showing on the dipstick. They filled the oil up and put it down to a dodgey dealer!
Its not not far away from its 15,000 service and they have just checked the oild again and in 3 weeks the oil is now 1/2 down on the dipstick.
Is this a common thing for the Fiestas? Or is this one 'special'? What do you suggest we should do?
Thanks guys,
Paul
newi is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2010, 11:33 AM   #2
mac_man_luke
mac_man_luke's Avatar
I wonder if the dealer put synthetic oil in at 3000...
2015 Toyota Landcruiser 79 V8 SC
mac_man_luke is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2010, 12:58 PM   #3
newi
Sorry I am not really familiar with the different oils. So the factory fill is non-synthetic and synthetic oil is not recommended for the first 15,000k?
Old 19-11-2010, 01:50 PM   #4
dannyhilton
dannyhilton's Avatar
The factory spec oil is made specifically to help the engine wear in. After a certain time you can put synthetic oil in which I found made the engine run a lot smoother.
I had synthetic oil put in upon my request at the 3,000km service and my car doesn't guzzle oil? Not sure buddy, perhaps they put the wrong oil in, might be best to take it back to the Ford Dealer for them to look at?
CURRENT: 2017 Escape Titanium 2.0L EcoBoost with Technology Pack in White Platinum
PREVIOUS 2015 Fiesta ST / 2012 Focus Titanium / 2009 Fiesta Zetec / 2004 Fiesta Zetec
dannyhilton is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2010, 06:38 PM   #5
kiwijohn42
Death B4 Decaf
kiwijohn42's Avatar
Some dealers will put in any old oil, regardless of what the logbook says.
I've always used Caltex Edge sport 5-30w fully synthetic, & don't use a drop between services.
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded.
kiwijohn42 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2010, 09:32 PM   #6
GoesLikeAZetec
GoesLikeAZetec's Avatar
could be a chance its got a small leak somewhere?
GoesLikeAZetec is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2010, 12:04 AM   #7
Fi.ES.TA
Fi.ES.TA's Avatar
Yeah doesnt sound good mate mines done 55,000klm and had 4 oil changes
and not lost a drop between changes.
Fi.ES.TA is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2010, 11:51 PM   #8
newi
I don't think it does as it doesn't leave any dribbles on the garage or at work and around the engine looks pretty clean... Back to the dealer it goes.
Old 25-11-2010, 07:57 PM   #9
small_ford
I have a Focus in NZ with the same 1.6 engine (not VVT though). Over 10,000km the oil level goes from the top mark on dipstick down to close to the bottom mark - I top it up with about 300ml of oil before it reached the bottom indicator. The oil is Castrol Magnatec 5w-30. The engine has covered 130,000km. I would consider that normal for the mileage, when it was younger it used some oil but not as much. From what you say there appears to be a problem. I would record your concern with the Ford dealer in writing now, so there is a record of the issue. They can initially check for a leak. Then, the only way to measure what is happening is to have the oil changed, check it is at the top level, then check the level every week or so, and record the level. Write it down so you have a record, take photos if possible. Then, when you have say 3-6 months of data (depending on the mileage covered0, if there is a problem - i.e the level is constantly dropping, you need to approach the Ford dealer with the data stating that this is a defect that you want repaired under the warranty. What they do to rectify will depend on their diagnosis of the problem. That's just my thoughts, hope it helps.
small_ford is offline   Reply With Quote Multi-Quote with this Post
