Old 06-10-2005, 06:03 PM   #1
slamd ef wagon
Default cams new or reground??
gdays guys after ur advice ive been incontact with both crow and wasde both are 120 for a regrind and 390 for a new cam now they saw i dont need to fit shims with the new cam and its very messy if u have to fit these shims now im new to cams and airnt all up to whats what so i dont even kno what a shim is
how hard is it to fit the regrinded cam??
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS
slamd ef wagon is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2005, 06:06 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
regrind means removing rocker gear, remove cam, removing all the lifters, shim up as required, refit lifters, drop in cam, put rocker gear back on.
billit cam means remove rocker gear, remove cam, drop in cam, put rocker gear back on.
there is nothing wrong with a regrind cam.
what grind you lookin at?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 06-10-2005, 06:19 PM   #3
slamd ef wagon
well wasnt sure on the wade cos i just asked how much for a performance cam for an ef but i was looking at the no3 cam from crow cams supose to give from 101kw to 120kw
what cam you guys suggest from wade?
anyone useing the no3 crow cam?
thanks for the reply effalcon appreciate it
Old 06-10-2005, 06:24 PM   #4
uglybob
XRWANAB
uglybob's Avatar
stg 3 will require a chip - my mate dropped a stage 3 crow into his manual EF & it wouldn't hold an idle.
i've a stage 2 with XR ecu, and idles pretty well ;)
'95 EF MkII Futura: http://www.cardomain.com/ride/980413/1
uglybob is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2005, 06:24 PM   #5
EDXR6T
shims are **** easy to fit thay'r the flat circuler washer things insid the roller rocker u take the lifter out then add a extra shims pluss ull need some sorta lube around the lob's and on the part of the cam that sit on the bearing (even tho e-series dont have bearings:P) but i talked to the guy that grinded ny cam he was from wade cams he recons ther just as good if not better plus u save a load shims ar bout 5buks from ford
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2005, 07:21 PM   #6
niko
likes falcon's
niko's Avatar
uglybob, gas would fix that :P
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
