06-10-2005, 02:52 AM | #1 | ||
its not a!
After a long drifting session in the wet the steering got really heavy, had a look and its fluid was empty. I filled it up again and did lock to lock a few times to work it through, and after three days its dry again and the heavy steering is back.
Tomorrow im gona get it up onto the ramps and have a look, does anyone know what would be the most likely problem? So i know what im looking for.... Will it keep happening every time i have a little fun? Also does this happen to anyone else after a hard drive? The bloody thing is also pullin to the left heaps now, i just got the alignment fixed a few months ago :(
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
06-10-2005, 08:58 AM | #2 | ||
PM me if you want
check the switch on the rack they usually leak.
06-10-2005, 10:24 AM | #3 | ||
hibernating
yeah my brother's car has done the same thing.... where abouts is the switch on the rack? do you just buy a new seal for it and replace the seal? i still need to have a proper look at it
06-10-2005, 10:53 AM | #4 | ||
its not a!
can you see it when looking under the hood?
Or do i have to get under the car?
06-10-2005, 11:03 AM | #5 | ||
ProuD EA OwneR
yes my switch always goes, its on the drivers side of the engine down the bottom its got a plug in it, its coming out of the rack.
EA 88 Fairmont Ghia pacemaker competition extractors "No.4480" redback 2.5" straight through exhaust Lowered by king springs (SL) Stereo by pioneer,fusion and kenwood Brock Falcon Bodykit thanx to chad :sm_headba velour interior: full body respray(BLUE MIST)
06-10-2005, 11:13 AM | #6 | ||
its not a!
ok, last night it was dry and i had to empty the bottle of fluid i had in my car, its was just a tiny bit...
Right now the fluid is absolutely full and is overflowing out the filler?!? what the heck!
06-10-2005, 11:13 AM | #7 | ||
likes falcon's
its can last 5000k's (new switch) or 30,000k's
there crap! mines gone to,
www.carhubsales.com.au |
06-10-2005, 11:23 AM | #8 | ||
Parts bin special
Yeah, mine did the pressure switch a couple of weeks ago. Was emptying the fluid out all over the carpark in under 2 days. (The fluid trails are still there) As mentioned, it is on the right hand side of the engine, down the bottom. You can see it and get to it from under the hood. Should take 10 to 15 minutes to replace it.
06-10-2005, 11:50 AM | #9 | ||
likes falcon's
apaprently all that switch does is bump up the revs under dry steering load...
mines unplugged with my manual setup (the connecter broke) and i havent had any issues watsoever, its more of an auto tranny thing.
06-10-2005, 12:07 PM | #10 | ||
its not a!
mine is a manual
Its a 1988 EA spak 5-spd The steering is fine now, it sorted itself out. But i found where im losing fluid, on the passenger side of the car there is a leak coming from the rubber bootie on the rod. Im gona jack up that side and have a closer look. There is no leakage from the switch, although i might replace it because i have a unlic EA for parts. Only done 180,000kms so its switch is probably in better nick than mine (340,000kms)
06-10-2005, 12:15 PM | #11 | |||
Parts bin special
06-10-2005, 12:43 PM | #12 | ||
its not a!
are those rubber booties meant to fill up with fluid? because mine are :( its very much broken me thinks
06-10-2005, 12:49 PM | #13 | |||
Low and Loud
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
06-10-2005, 12:51 PM | #14 | ||
its not a!
yeah, they were filled up to the point of nearly bursting, i squezzed one and all the fluid ****ed out, both are stuffed :(((
06-10-2005, 12:55 PM | #15 | |||
Low and Loud
06-10-2005, 01:09 PM | #16 | ||
likes falcon's
why dont u just pull one apart and put new o rings in it, had to do that with my last rack worked a treat ;)
06-10-2005, 02:44 PM | #17 | |||
its not a!
I have two unlic EA's out the back, ill just do the ole swap'a'roo. Its not too much of a job is it?
06-10-2005, 04:12 PM | #18 | |||
Low and Loud
06-10-2005, 04:20 PM | #19 | ||
im waiting for mr political to say ""i sincerely hope that the drifting was done on a race track or private strip"
06-10-2005, 05:43 PM | #20 | |||
its not a!
yes, yes it was :newangel: The tie rod ends are basterds to get off.... mr Gregory says "Disconnect the tie rod ends from the steering arm by holding a hammer or suitable dolly against one side of the steering arm and striking the opposite side with a hammer" I think mr Tie Rod End is gona have an overnight stay with mrs WD40....
06-10-2005, 07:10 PM | #21 | ||
likes falcon's
ive seen the orings replaced, it took 30min that included driving to a bearing joint to get the orings...! lol
06-10-2005, 08:17 PM | #22 | ||
One of the major causes for the Switch to blow out is constant hard lock to lock transfer. When you do that it boosts the pressure in the rack and blows seals in the rack and also out the top of the switch. When EA's were new that was a CONSTANT problem but these days not as bad. Ford has a modified switch and it is a lot better.
Beware of after-market switches, they MAY be cheap but that also equates with Nasty? :( Just for your info guys, EA-ED Racks are STILL available from ford. They are exchange units but are well prepared for Ford. |
06-10-2005, 09:39 PM | #23 | ||
Custom user title
the swtich in my eb is still the origanal item.... over 220,000 km...if a new stiwtch only lasts somthing 10000-30000 km.. its getting installed incorectly (done up to tight) or its getting knocked.
I agrea an exchange rack is the go.. STUFFFF doing it ya self.. just asking for trouble |
06-10-2005, 10:24 PM | #24 | |||
Incidentally, my rack is original, as is the switch, and the car has done over 200,000 ks - no leakage whatsover from the switch. However, my RH boot does have fluid in it - i'll be rebuilding a rack soon anyhow. |
06-10-2005, 10:34 PM | #25 | ||
likes falcon's
why is this switch in fords and not in commos?
and wat exactly is it called.
06-10-2005, 10:35 PM | #26 | |||
Low and Loud
06-10-2005, 10:57 PM | #27 | ||
likes falcon's
dude there practically the same steering racks.... just ford have a switch, commos dont. lol
