Old 27-02-2011, 07:02 PM   #1
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
Default Evap to reverse cyle aircons
hey folks, just wondering if anyone here has converted their old evap to a reverse cycle aircon using the current ducting, or is it even possible? Missus is over the hot weather in perth atm. Otherwise its a split system in the rooms.
Thanx in advance
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 07:10 PM   #2
05_ENFORCER
05_ENFORCER's Avatar
If you go with a split system, consider a ceiling cassette.
Bang it in the largest room, normally dining/entertainment, cools most of the house quite well, just bearable.
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 08:07 PM   #3
jaydee
jaydee's Avatar
Thanx in advance
I hear ya mate, we're in the same boat. Damn humidity, evap is near on useless.
We have a large refrig in our kitchen TV area, and just close off all the doors and veg out infront of the TV, but as soon as you go to the bedrooms, whew, melt.
I think you can do the conversion but very expensive, thats why, me being a cheapskate, went for 1 refrig unit.
Have a look at the ads they have in the TV guides from the weekend papers.
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 08:27 PM   #4
05_ENFORCER
See if you can put up with it for a couple of months (autum/winter) that's when the prices plummet from around 14,000 to 9-10,000 for a large 4 x 2.
There is a place that will design the system for you and you can buy the ducting and extras from them.
I think in Kardinya/Myaree maybe??
Install yourself, grab a sparky/fridgy mate, save bucketloads.
If you want trade/contractors price PM me
Old 27-02-2011, 08:51 PM   #5
macca13
We had full ducted reverse cycle air-con fitted about 6 months ago.
$9500 fully fitted removed and disposed of the two old splits. Cools our 4*2 house to cold any day. Fitted by Jarrahdale air in one day no dramas at all. Quotes are free get them out and ask about the ducting.
macca13 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 08:59 PM   #6
05_ENFORCER
And Jarradale have decent full time installers as well.
Old 27-02-2011, 08:59 PM   #7
svo347
AFF's 1st DM.......
svo347's Avatar
Cheers people, i do like the casette styled ones. There goes the FMIC and zorst for the terry, hard decision
13.21 @107.7mph
Old 27-02-2011, 09:06 PM   #8
Sam
Evap ducting is too big to run as a conversion. Most installers would want to replace the entire system rather that retro fit. Just rip the old swamp donkey out!!
Sam is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2011, 09:12 PM   #9
05_ENFORCER
Not a hard decision at all mate.
Keep the missus happy for now, plan for more mods later
Old 27-02-2011, 09:14 PM   #10
05_ENFORCER
Yep, massive advancement in duct types/insulation and electronic dampers for each room nowadays.
Out with the old and in with the modern.
Old 27-02-2011, 09:40 PM   #11
ebxr8240
Performance moderator
ebxr8240's Avatar
Ahh happy wife... Happy life !!! Even if she's cool... Lol...
Daily driver GTE FG..
Old 27-02-2011, 09:55 PM   #12
svo347
AFF's 1st DM.......
svo347's Avatar
Im hearing you there Graham
13.21 @107.7mph
Old 27-02-2011, 10:07 PM   #13
You might want to try (or investigate trying) a larger fan motor in your evaporative system if you can. If you have a Breezair for example you can usually change to a larger wattage motor and re-gear it to give a much larger air volume output. It will make a noticeable difference in terms of cooling in this weather.
You can go too far and destroy the fan of course and you will have to be careful to leave enough windows open so the air can escape or you will blow your duct walls out or off their outlets.
Check with whoever sells spares for your system as you will often well find that there is a higher output fan motor designed for your existing evap box when more outlets are connected. You can usually also adjust the fan pulley diameter for the new motor so its spins faster. This will need to be set up by an electrician or if you know how using a clamp on ammeter to get the pulley size to match the new motor.
I found this out by accident. I have an 11 outlet Breezeair and when the motor failed the only one available was one designed for a system with more outlets (20 I think). When it's like this I set it to high and I have my own cooling mini-cyclonic wind. The extra air movement make a very noticeable difference on humid days like this. It's only when it's like this and when the dog does one of her noxious burnt rubber I set it to high. Even on the lower setting everyone remarks how much cooler our system is than theirs.
Higher output water pumps for these systems are also available but I have needed to go down that path yet. And if it's only for a few days a large solid block of ice in the evap roof box each day will make a real difference too (I used to do this in a previous house).
Old 27-02-2011, 10:10 PM   #14
Note also the our Government has been threatening to separately power all refrigerative air conditioners so they can turn them off in peak consumption periods so refrigerated air may end up meaning no air when you most want it.
Old 27-02-2011, 10:12 PM   #15
See http://www.zdnet.com.au/wa-utility-t...-339289186.htm
http://www.mediastatements.wa.gov.au...?ItemID=130233
http://au.news.yahoo.com/thewest/a/-...-to-pay-price/
Re Big Brother or Nanny State's remote control of air con use.
Old 27-02-2011, 10:15 PM   #16
svo347
AFF's 1st DM.......
svo347's Avatar
Thanks aussie
13.21 @107.7mph
Old 27-02-2011, 10:59 PM   #17
See here for the Breeezair options:
http://www.aercomountisa.com.au/eaparts.html
095011 Motor 2 Sp. 250W 240V
095028 Motor 2 Sp. 380W 240V EA70 Range
095042 Motor 2 Sp. 560W 240V EA90 + EA100
095066 Motor 2 Sp. 750W 240V EA120
095080 Motor 2 Sp. 1100W 240V EA140
095097 Motor 2 Sp. 1500W 240V EA150
but you need to match the motor to the other parts
eg
500607 Fan Centrifugal Small EA70 Range
501307 Fan Centrifugal Medium EA82 + EA90
506807 Fan Centrifugal Large EA100 to EA150
Tank Small DD EA70D
505008 Tank Small SD EA70WV + 70S
505206 Tank Medium DD EA82 + EA90
505107 Tank Medium/Large SD/TD EA82 to EA150
505305 Tank Large DD EA100 to EA150
Lid Small DD EA70D
505107 Lid Medium/Large SD/DD EA82 to EA150
505008 Lid Small SD EA70WV + EA70S
505305 Lid Medium EA100, 120, 140 Top Discharge
604602 Lid EA150 Top Discharge
3 505404 Panel Front Small EA70 Range
505503 Panel Front Medium EA82S + EA90S
505602 Panel Front Large EA100S to EA120S
4 505701 Pad Frame Small EA70 Range
505800 Pad Frame Medium EA82 + EA90
505909 Pad Frame Large EA100 to EA150
5 100159 Filter Pad Small EA70 Range
100203 Filter Pad Medium EA82 +EA90
100258 Filter Pad Large EA100, 120, 140, 150
502106 Shaft Fan Small EA70 Range
504605 Shaft Fan Medium/Large EA82 to EA150
800523 Bearing Kit all Models
501703 Pulley Fan 225Dia. all Models
100869 Pulley Motor Large Dia. 108
etc etc
Old 27-02-2011, 11:50 PM   #18
svo347
AFF's 1st DM.......
svo347's Avatar
cheers mate, heres to things getting cooler in perth hey :(
13.21 @107.7mph
Old 28-02-2011, 12:51 AM   #19
Yes; it would be nice; their in no air con in the shed and I things I need to do.
Old 28-02-2011, 05:25 PM   #20
bungarra
We used Jarrahdale to replace our Cool Breeze unit, notice a big difference in comfort levels even in the extreme heat, only issue is really high humidity days where we get a lot of condensation on the tiles. They could have converted the evap to refrigerated for our home, but didn't have 10K to spend and the wife was pregnant and a hot summer last year when the other air con bit the bullet.
Jarrahdale installers did a great job and we had an issue with the drain valve, phoned them up, fixed same day.
bungarra is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2011, 05:34 PM   #21
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Yeah we've got one of those old school through the wall box air cons for our main room (3x1 duplex) and in there its fine, as soon as you go into another room you boil.
I like the cassette style ones, my Mum has a Fujitsu one at her house and its whisper quiet and cools quite well. Better than the stupid LG one she had thats like sitting behind a jet engine with all the noise to go with it.
But yeah, sick of these hot nights. Bleh.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2011, 05:42 PM   #22
ozfast
ozfast's Avatar
swampy's are useless in the current conditions we are having,the ducting for your evap will be of much larger diameter (some 600 diameter) and therefore be useless on your new system,daikin are one of the best units to use and are good to deal with for after sales warranty issues (hopefully you don't need them)
ozfast is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2011, 07:43 PM   #23
jaydee
jaydee's Avatar
...or put your Mrs in the Terry and run the A/C in the car, just bring her out a sandwich every now and then.
jaydee351
4DV8
Old 28-02-2011, 08:27 PM   #24
atec77
Thanx in advance
We installed a special air underground system http://mb-soft.com/solar/saving.html google will tell you
Had an ac engineer design it and costs a fraction of the usual ac costs due to being a simple volume air fan , the air is moved through underground pipes getting a drop of 5 to 7 deg minimum and all you pay for is running the fan , it doesnt freeze you but its lots better than a swampy ad=nd way cheep
atec77 is offline   Reply With Quote Multi-Quote with this Post
