#31 | ||
speed bumps should only be for high speed hoons, why should those of us who can drive safely through or out from a carpark have to suffer?
If they made them a bit lower the hoon crowd with the lowered vehicles would still have to slow while others who would not speed in excess anyway through the area would not have to as much. Some speed humps are easy enough to go over at 20-30 k's while others scrape your car underside even if crawling over so why the difference? Or rather what sort of moron makes them so damm high? |
#32 | ||
let it burn
Im surprised no-one has thought to challenge them based on 'greenhouse' gases. Constant braking and accelerating along some of the streets that have them must be doubling the emissions, more than double if they have several along a street. Accelerating and changing gears burns more fuel than cruising at 50.
#33 | ||
Seeing as how the whole idea of a "speed hump" is to slow you down at a particular point, why would you be so concerned about whether you can just flog over them without slowing down?
That also explains why there isn't a design of hump that "allows you" to not slow down. They are supposed to slow you down... ![]() And if your car "scrapes" then it is either A: lower than the legal 100mm limit, or B: something is up with your suspension/you are taking it too quick and when your suspension compresses on the other side it scrapes. |
#34 | |||
Dont know if your talking to me or someone else here however your reasoning is somewhat flawed. Point 1 yes speed humps are designed to slow cars down however most of us can slow ourselves down when & if needed as in a maccas carpark, I mean speed humps or not I would still drive slow through them so how do humps help make me a safer driver? Point 2 The design point I made was that they vary a great deal even within the same carpark & some are so high that even a stock standard new car like mine scrapes badly. Point 3 I have already answered this mostly in my reply "point 2" however again you say oh your driving too fast & then braking & compressing your suspension, well NO I crawl over the larger ones I am referring to making sure not to compress or bounce suspension & it still scrapes & remember I have a stock standard vehicle with suspension in good order. So come on give me intelligent replies to my 3 points if you can. |
#35 | ||
Most of us would only need a sign saying 10 or 20 kph etc with no humps ty
#36 | ||
Speed bumps slow down honest law abiding citizens.
The people in 15 year old cars who don't care about anything still fly over them. Whats worse is this stupid slow points. They just put a random obstacle in the middle of a normal straight lane, so you have to drive around it. How is that safe. I hate normal roads that have many really slow speed bumps in unnecessary places. I normally floor it between these bumps in spite of them. I have nothing against reasonable speed bumps in necessary places. |
#37 | |||
Regular Schmuck
#38 | |||
