17-03-2011, 02:18 PM | #1 | ||
The Willing Listener
Heater was working and now there is no hot air whatsoever. Very luke warm out of windscreen demister only. Fan is working great. Car is running mid/low range in radiator temp. Don't really wish to pull dash out as last resort to rectify if possible. Winter is coming on and I don't wish to freeze my n_ts off.
Any help is appreciated. |
20-03-2011, 01:41 AM | #2 | ||
check that the heater tap/air blend door is not stuck in closed position>Also ,check your heater core and heater hoses are not blocked.
20-03-2011, 09:15 AM | #3 | ||
Your thermostat is most likely jammed open. The sooner you replace it the better, as not only will your heater not work, your engine can wear out prematurely.
