Boss 335
Is there some way to change a normally closed switch to operate as a normally open switch. The only way I can see is with a relay and power source. I need to do this to get my door ajar sensors to work. BA/BF doors work on switch closed = door open, while FG BEM works on switch open = door open.
#2 | |||
* Can you check the door switch and see if there is 3 terminals? ie both a NO & NC with a common terminal? * Can you buy another door switch which will mount correctly? If you are unable to rewire / change out the door switches to suit what you require. Bearing in mind there are many limit switches available. Be it Ebay or robot (just google it!!) supplies etc. Then setting up a circuit to as you suggest with a relay and power source is the only way to go. Just try to get one which is okay with the load / burden (most likely not much of a problem at all) to provide the circuit to the FG BEM. Give me a PM if required! Good luck! PS Go Webber ![]()
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
I'm no help to you... I just read that 5 times and I'm still goin.. Wha?? Lol
Maybe I need to go to bed
_____________________________________________ Jo |
Boss 335
Thanks guys. I will need to dismantle the whole lock assembly in the BA door to see if there is a third pin. Or maybe an e-series door ajar switch retrofit might do the job.
i think the easier option is to call FTG and seen if you can get some door relay's off an FG, but if there is and auto sparky or even a normal sparky they may be able to tell ya how to do it. but i think new relay switch would be easier
Boss 335
FG door lock assembly is all-in-one as well, and it doesn't fit into BA door without a lot of modification
you can use a 5 pin changeover relay to convert it
![]() Join Date: Oct 2006
Is this for a burglar alarm? If not tell us why and there may be another solution.
regards Blue |
windsor user
tipping he's fitted an FG cluster and trying to get door adjar sensors to work
#10 | |||
Boss 335
#11 | |||
Boss 335
Perhaps swap them for some burglar alarm pin switches that are normally open
eg http://www.altronics.com.au/index.asp?area=prod&grp=279 or http://www.jaycar.com.au/productView...s&form=KEYWORD
regards Blue |
#13 | |||
Boss 335
