Old 30-07-2011, 06:00 PM   #1
GTP 044
Formally RED XR8
GTP 044's Avatar
Default Condensation in garage
Hi everyone,
I am having an issue with condensation in my garage at the moment. Unfortunately I don't have any sisalation under the tin roof and I am getting water dripping all over the GTP which is pi$$ing me off. I am wondering if i install a "whirlybird" on the roof would this help fix the problem due to increased airflow in the garage???
Thanks in advance,
Greg.
PREVIOUS '03 GT-P Manual, Sunroof, Sat nav, Leather, reverse sensors
The only FPV ever built in CONGO GREEN
SOLD
CURRENT 2012 Manual, leather, sat nav GT 335 in SWIFT GREEN
1 of only 6 manual Swift Green GT’s and 1 of only 21 Swift Green GT’s in total
GTP 044 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2011, 06:09 PM   #2
burnz
VFII SS UTE
burnz's Avatar
Default Re: Condensation in garage
air condition it...then put TV, pool table, bar, jacoozie..
and i'll be over soon!
would it be a hot motor drawing the condensation?
edit: just an air gap (small) between the walls and roof.
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2011, 06:12 PM   #3
SEZ213
SEZ213's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always puts a good amount of thought into his posts and voices his ideas and opinions in a well thought out and constructive manner. I have certainly seen many threads where his input has been constructive to the topic and overall the forum has benfited f
our back deck does the same thing, the iron roof gathers condensation and drips down onto the deck, but it's completely open...the deck boards are separated, and it's just railing around the edges.
Is it getting very cold down in Mornington, or does it happen all the time?
2012 Focus ST
Tangerine Scream
Continually having a battle of wits with unarmed opponents.
Sez
Photo's by Sez
SEZ213 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2011, 06:39 PM   #4
GTP 044
Formally RED XR8
GTP 044's Avatar
Yeah mate it has been freezing down here overnight lately.
SOLD
Old 30-07-2011, 06:50 PM   #5
fat4D
might sound like a silly option, but its simple. rig up a tarp just below the roof line? or even if its a beveled roof get some PVC pipe of a resonable size cut along to make a tray that goes to a drain? as im assuming its gathering right in the top joint as the car sits there slightly hot in the arvo and as it cools and turns to condensation comes back down?
Now Ford-less
But good things are coming in 6 months
fat4D is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2011, 06:59 PM   #6
SEZ213
SEZ213's Avatar
These might help, there's a few different solutions in there...Burnz actually said one, but I don't know if he meant it in that fashion...was Airfill (like bubblewrap)...
http://www.gmh-torana.com.au/forums/...ation-in-shed/
http://forums.whirlpool.net.au/archive/1345680
Good luck!
2012 Focus ST
Tangerine Scream
Sez
Photo's by Sez
Old 30-07-2011, 07:34 PM   #7
Jim Goose
Its because of the cold weather and the sun hitting the roof in the morning.
A whirly bird wont make much difference.
Is the garage door left open over night? That may help even the air temp inside and outside of a morning.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2011, 08:06 PM   #8
ebxr8240
Performance moderator
ebxr8240's Avatar
Ventilation to keep temps equal.. An extractor fan either driven off elect or solar..
Make sure NO moisture is getting under floor etc...
A dehumidifier or tarp over car ???
http://www.appliancesonline.com.au/d...FcYNHAoddFxZXw
Daily driver GTE FG..
Old 31-07-2011, 06:32 PM   #9
GTP 044
Formally RED XR8
GTP 044's Avatar
I have a side sliding door which opens into my backyard, I might try leaving it open a small amount to see if that helps. If not, I will have to install some sisalation. Thanks to everyone for your advice.
SOLD
