Old 31-07-2011, 06:32 PM   #1
DZFord
DZFord's Avatar
Default New engine mount
Over the last few months I have noticed increasingly worse vibration through the cabin, especially when at idle and under acceleration. I suspected one of the engine mounts was to blame and after some research, found out that the upper (driver's side) engine mount was prone to failure. I picked up the part from Ford ($230) - and with the help of a mate yesterday, we swapped it over. The old engine mount rubber was cracked and compressed and had way more play / give compared to the new mount.
There are a total of 3 mounts on the LS/T/V - 1 x upper mount (cabin insulator), 1 x rear mount (roll / torque restrictor) and 1 x transmission mount.
When swapping it over, I'd recommend an engine crane to take the pressure off the mount, but you can get away with blocks of wood + jacks under the sump if you're game. A torque wrench is also essential for re-tightening to new mount to spec.
I was so amazed as to how much difference the new mount made to ride comfort and how little cabin vibration I have now. Highly recommended!
Here is a good youtube clip of what is involved on a US Focus (some things are slightly different): http://www.youtube.com/watch?v=q_r0Jh294FM
Old 01-08-2011, 02:08 PM   #2
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Default Re: New engine mount
Excellent info DZ. As far as you know, was the MK1 prone to engine mount failures?
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2011, 02:51 PM   #3
DZFord
DZFord's Avatar
I did not come across any Mk1 failures, just plenty on the Mk2 and the Mazda 3, which use near identical mounts.
Old 02-08-2011, 05:24 PM   #4
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Thanks mate.
