Adams Polishes
Old 11-08-2011, 11:04 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Bit of an urgent one - PC help
my laptop has decided it doesnt want to run .exe files anymore. I had a virus that was posing as a Windows Internet security program, which I removed by deleting the file. Now I cannot get any .exe programs to run at all - even if i download an antivirus program, the pc will download it but cant run it - asks me to select the program to run it from a list but it is an executable file?
Any ideas on what I can do to fix it?
2024 F150 XLT
Old 11-08-2011, 11:06 PM   #2
GreenR
GreenR's Avatar
Default Re: Bit of an urgent one - PC help
have you tried right clicking on the icon and selecting run ?
GreenR is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2011, 11:09 PM   #3
b2tf
b2tf's Avatar
Yeah i did try that but I just fixed it by downloading an exefile fix utility. Seems to be going ok now.
The missus downloaded one of those games from the 80's things and it had a virus in it so I am now in the process of cleanup/fixup.
2024 F150 XLT
Old 11-08-2011, 11:22 PM   #4
GreenR
GreenR's Avatar
Something like that sounds like file association error. Normally to do with problems in your registry. Get a program that is a registry cleaner helps fix small errors like that
Old 11-08-2011, 11:45 PM   #5
tjb45
have a read here: http://support.microsoft.com/kb/950505
It should sort the problem out..
tjb45 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2011, 09:43 AM   #6
lilmattie
lilmattie's Avatar
Also, download Malwarebytes Antimalware (free edition) and run a full scan.
Just to make sure that there's nothing else that's still there. It should also cleanup all the registry entries of that bogus AV malware..
If you're still finding odd things are happening - download a tool called combofix and let it run. I've used it many many times to remove rootkits.
Wanted Parts
  • Control knobs for XA/B dealer-fit full length under-dash aircon.
  • VGC XA/B dashpad in black
lilmattie is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2011, 09:47 AM   #7
b2tf
b2tf's Avatar
Thanks for that, I have just put Malwarebytes on here now and its scanning. Be interested to see what it comes up with.
2024 F150 XLT
Old 12-08-2011, 10:06 AM   #8
ch33z1l
Dawn
ch33z1l's Avatar
CCleaner will clean up temp files, redundant files, registry errors, as well as free up some space.
http://www.piriform.com/ccleaner/download
ch33z1l is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2011, 10:06 AM   #9
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
I use this program daily, I run it each time before switching off the computer after internet browsing, you'll be surprised what it will pick up from the registry and fingers crossed my PC has been bug free for quite some time and it seems to run quicker as well. It's also free and has auto updates available
Edit -Beat me by a millisecond
http://www.filehippo.com/download_ccleaner
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2011, 10:18 AM   #10
lilmattie
lilmattie's Avatar
Good call guys. Temp folders are also places where other nastys can lie dormant.. or be active..
Wanted Parts
Old 12-08-2011, 11:21 AM   #11
ch33z1l
Dawn
ch33z1l's Avatar
Have also seen something similar on a Windows 2003 Server, where the security settings would prevent any .exe files from running. If you open the file properties, is there an unlock checkbox that you can tick? I think this is pre-service pack 2...
It does sound more like a virus/spyware/registry issue?
Once Malwarebytes is finished scanning, download Spybot Search and Destroy>Update>then Immunise, just to be sure you got it all.
The other issue could be that your profile has lost administrative permissions. Try creating a new user account with Administrative priviliges. Copy your documents, music, etc and delete the old profile.
Old 12-08-2011, 11:25 AM   #12
ch33z1l
Dawn
ch33z1l's Avatar
First thing I install on any PC, be it my own or a clients. I've found the 'Wipe free space' is heaps better than the Windows Drive Cleaner.
Piriform also make some other awesome programs. Recuva is also very good. Haven't bothered with Defraggler, as the default Windows one is sufficient.
Old 12-08-2011, 01:23 PM   #13
b2tf
b2tf's Avatar
I do have CCleaner on there and use it pretty regularly too.
2024 F150 XLT
Old 12-08-2011, 02:54 PM   #14
Zero_PSI
Zero_PSI's Avatar
Have you tried running the prpgrams from the command prompt?
It sounds like a damaged file on yhe operating system, the most permanent thing to do would be to reformat the affected volume and re-install the operating system. Do this via a windows image file to avoid losing all your applications. anti-virus software can removw virus' but can't repair damaged data.
This is why we create restore points people.
Zero_PSI is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 06:37 PM   #15
Josh_XC
Run your box in safe mode, you should than be able to run .exe files, if this is the case go to run ->msconfig and see what is running on startup and remove anything suspicous. Oh also do a scan while in safe mode
Originally Posted by MYLO_XR6
i dont like motors that come in the same size as milk and orange juice
Bionic BF XR8 - 6 speed manual, reversing sensors, premium sound, GT starter button. 218rwkw - Got to love the BOSS!!
Josh_XC is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 07:00 PM   #16
FGII-XR6
FGII-XR6's Avatar
Or back up your critical data then format & reinstall , nothing like a clean install to get some speed back into your system so you get a bonus as well.
some see this as overkill but I like to reinstall my OS every few months (except on my 2 servers) performance always improves after I do this. I know there is maintenance you can perform to keep your system running well but they are not perfect, you OS gets tired after a while
Don't put your data back untill you install a good AV program with all updated installed this will trap any gremlins for you
[SIGPIC][/SIGPIC]
Rides:
