Old 23-08-2011, 08:44 AM   #1
Autolite
Autolite's Avatar
Default What would you do?
I finally decided to pull the speedo out of my car (XYGT) because it was making a whirring/grinding sound . Had the cable disconnected the the last couple of months cos it was so bad. After a couple of hours getting it out I decided to go for a quick drive so I hooked the cable back up to it and off I went. i drove for approx. half an hour and you guessed it, it was perfectly silent. Do you reckon I should lubricate it up and throw it back in or take it to a shop and have someone give it the once over? If so can anyone recommend a place in Melbourne to have alook at it?
Autolite is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2011, 08:51 AM   #2
aussie muscle
aussie muscle's Avatar
Default Re: What would you do?
Lube up the cable would be a good start, since it's a mechanical speedo.
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2011, 02:06 PM   #3
kopyme
I have used graphite powder in them before with great success. Not sure if that will help your problem. It worked for me.
Chuck a skid bro!!
kopyme is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2011, 02:57 PM   #4
mik
mik's Avatar
if you`r worried you could get it serviced by an instrument restorer/technician, sorry no idea where in melb, for a good car like yours i think i`d get it serviced.
Old 23-08-2011, 03:32 PM   #5
Bud Bud
Are you saying that you have the speedo still connected but sitting in your lap while you are driving, and now it is silent? It may still be making the noise but it may not be audible because it is not screwed down to the dash. It could be that the noise you hear is amplified once it is fixed solid. I would at least eliminate this first before I put it all back together.
Bud Bud
Bud Bud is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2011, 03:40 PM   #6
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
if the speedo has never been recoed, you might aswell get it done.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2011, 04:17 PM   #7
gcg2503
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always adding valued comments,  never involved in any disputes. A credit to this forum.
Get it checked out by Howards Instruments mate
They recalibrate speedo's, get them working, even reco fuel senders etc
http://www.howardinstruments.com.au/
Phone : 61 3 9457 4755
110 Northern Rd,
Heidelberg Heights,
Victoria 3081, Australia
gcg2503 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2011, 09:01 AM   #8
kopyme
Ringwood speedos may be able to help with this too...
Chuck a skid bro!!
Old 24-08-2011, 01:32 PM   #9
MarkAW
Uncouple the speedo head from the cable, remove the inner drive cable and see if the cable has previously had a dry lubricant, like powdered graphite or a wet lubricant like grease or oil. Also check for any damage to the cable. Neither dry or wet should be mixed as it will gum up the cable. Give it some more of what ever it had before by tipping just a small amount down the inside of the outer cable and you should be good to go. Don't over do it or fill it up, just a very small amount.
If there is nothing wrong with the speedo, then why pay good dollars for the same thing from a repair shop.
__________________________
They call it a rort when they're not in on it
Mark
MarkAW is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2011, 01:49 PM   #10
05_ENFORCER
05_ENFORCER's Avatar
These cables can break down near the sender.
Try driving a short distance with the speedo off and see what heppens.
The inner core should turn.
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2011, 04:21 PM   #11
Autolite
Autolite's Avatar
Thanks for the tips guys. I'll take it to howards and see what they think and i'll also try some lube in the cable.
Old 25-08-2011, 04:32 PM   #12
66FAIRLANE
66FAIRLANE's Avatar
I would just lube up the spinny thing on the speedo then reconnect it and NOT screw the nut all the way in. Sometimes the cable can exert pressure onto the speedometer drive and this can cause wear and the noise you hear. This probably explains why it was silent when you had it out of the dash. Cable was bent differently and wasn't exerting the same pressure.
I have done this before with success.
66FAIRLANE is offline   Reply With Quote Multi-Quote with this Post
