Old 31-10-2005, 09:10 PM   #1
joelman32
BA xr8 2004
Talking where to hook up input wire for tacho on EA?
does anyone know where to hook up the input wire for a tacho on the EA. it would be appreciated.
joelman32 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2005, 09:31 PM   #2
KeeddleZ
Road Runner
KeeddleZ's Avatar
if its an aftermarket tacho eg auto meter i would presume its the same as always to the negative (-) of the coil. If its the tacho in the cluster i wouldnt have the foggist.
KeeddleZ is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2005, 09:34 PM   #3
GenesiS
*Smart *** comment here*
GenesiS's Avatar
assuming your talking about a moster tacho type item, then usually it goes to the negative of the coil pack under them bonnet, thats how my old tach hooked up... use a multi meter, the negative should change readings in ac volts as you rev the engine...
1997 4.0L EL Falcon GLi Sedan Auto
2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe
Lowered all round on King Spring Super Lows
Tinted Windows, Pioneer MP3 Player and Audio System
K&N High Flow Air Filter Mounted in Original Air Box
Trip Computer
NGK Sports Performance Leads
NGK Sports Plugs
Autotecnica Oil Catch Can
GenesiS is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2005, 09:41 PM   #4
joelman32
BA xr8 2004
yeh i thought it went to the negative on the coil, but i cant seem to find the negative on the coil, it is ib a hard to reach place, under the exhaust manifold
Old 31-10-2005, 10:09 PM   #5
joelman32
BA xr8 2004
does anyone know where on the coil the negative is?
Old 31-10-2005, 10:45 PM   #6
EDXR6T
intake manifold u mean:P
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2005, 11:13 PM   #7
superloweb
Fairmont6
negative on the coil, well theres the earth wich earth to the egine, im pretty sure the negative would be in the plug that plugs on the back of the coil under the intake manifold, best use a hoist too so much easier to deal with coils on flacons from underneath
superloweb is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2005, 09:00 AM   #8
eav8
eav8's Avatar
There is a little wire which runs from the distributor to the coil...It has a connector about halfway alog..You could take a feed from there as that is the negative you are looking for.
Be aware there are some after maarket tacho that have to be connected to an auxillary feed line up near the brake booster rather than the coil.
Have fun
eav8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2005, 11:20 AM   #9
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
There is a pink wire from memory which ends up in a loom near your brake booster. Its a diagnostic loom which isn't used, so you can normally just hook into that....nice and easy.
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E
Tuned by Michael J's & Son.
EASPRINT is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2005, 08:36 PM   #10
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
pink and white wire in the dianostic port near fuse box near right knee
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 12:16 AM   #11
joelman32
BA xr8 2004
thanks for the help guys i will try them out.
