30-09-2011, 02:59 PM | #1 | ||
any thoughts/opinions?
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
30-09-2011, 03:11 PM | #2 | ||
rexnet
i think both are restrictive for memory. see paul and get him to slap on some pacemaker's
30-09-2011, 06:39 PM | #3 | ||
RIP...
I have a feeling they're the same.
In any case, short 4-1's like that are crap. A decent set of tri-y's are best for all street use, brands like H&M, Advance, Hurricane, Genie, and Lukey, all make sets which have good tube size and length.
. Oval Everywhere... |
30-09-2011, 09:58 PM | #4 | ||
I can pretty much get a set for the price of a smile so it was worth asking.
Yeah, when my house/bills stop hogging my cash flow allows me ill get paul to hook me up with some headers and CAI stuff too.
01-10-2011, 01:31 PM | #5 | |||
AU DIE HARD
These are stock 220 against stock T3 apart from the HP coating they are the same , you may be able to compare the 200s against the pictures
01-10-2011, 08:50 PM | #6 | ||
rexnet
are they pretty restrictive Whoosha? i dont know much but they kinda look like they all get put into 1 pretty quick.
01-10-2011, 08:59 PM | #7 | ||
Giddy up.
The 200 and 220 kw factory header's are the same, although I have seen one set from a 220 (susposedly) that was larger in the pipe exiting the cat then my old 200kw ones, but I have also seen other's from a 220kw that were the same diameter.
But in general they are identical, so if you are looking to get a gain going from 200kw to 220kw factory header's, quite simply you wont. |
01-10-2011, 09:03 PM | #8 | |||
Giddy up.
01-10-2011, 09:54 PM | #9 | ||
not here much anymore
The factory ones are great headers if youre looking to make the car dull and boring.
RAM 1500
01-10-2011, 10:51 PM | #10 | ||
Yep - my T3s are all dull and boring so it must be the factory headers doing it.
01-10-2011, 11:06 PM | #11 | |||
RIP...
The primary pipes are way to short, and they aren't tuned length. They are used from factory because they're cheap to make, easy to install, and a little better than an old style cast log manifold. A much longer primary pipe, and tuned lenght will improves things. Good tri-y's will improve things even further.
01-10-2011, 11:27 PM | #12 | |||
RAM 1500
02-10-2011, 09:17 AM | #13 | |||
RIP...
02-10-2011, 02:55 PM | #14 | |||
AU DIE HARD
Well with out getting into the pros and cons of it all if you have none then I would buy Pacey's or Diphilllipo's if you have a set of 220s sitting there I would use them,Thing is to Look at what your going to use your car for If its basically a streeter with a few trips down the track, I would go the cheap option , It comes down to bang for buck, Ford gear both on the AUs and BAs arnt that bad IMO. Its been a while since I was involved in a fair bit of the early testing with AU V8s, from memory the HP gain on the aftermarket headers was only minimal at best until you open the motors up a bit then they come into there own, especially the 4 into 1 stuff .
and sorry Sox the T3 set will probably end up on a XR8 Cortina
