11-10-2005, 07:39 PM | #1 | ||
She needs premium dude...
The NC has developed a constant ticking sound. I pulled the rocker cover off and it is coming from the front of the motor. I checked the lifters and they are not spongy so I dont think they are causing the sound. The number two inlet rocker arm has a bit of sideways slop in it. (More than the others) so could this be causing the ticking?
Cheers. |
11-10-2005, 07:44 PM | #2 | ||
tuff
injectors maybe?
.......................FG XR6 UTE........................... ......................xc fairmont gxl......................... ...................GQ coil cab UTE .......................... |
11-10-2005, 07:59 PM | #3 | ||
Last warning
exhaust manifold leak?
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
11-10-2005, 08:01 PM | #4 | |||
11-10-2005, 08:02 PM | #5 | ||
Hmmmmm
could it be the oil your using?
maybe its too thin? |
11-10-2005, 08:07 PM | #6 | |||
11-10-2005, 08:15 PM | #7 | |||
tuff
11-10-2005, 08:16 PM | #8 | |||
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG. |
11-10-2005, 08:46 PM | #9 | ||
tuff
hmm i think im running 10w30 atm -oil we use at work might need thicker oil huh
*back on topic*
11-10-2005, 10:01 PM | #10 | ||
i would say injectors just put ur finger on the injector and feel if its ticking at the same time. u wont get a shock or anything from it
12-10-2005, 01:44 PM | #11 | ||
- BOOYEH -
Yep, I think your problem is the I6. That V8 conversion you were tellin me about will fix it. LOL :
1993 EBII Fairmont Turbo T04e 7 psi
12-10-2005, 01:46 PM | #12 | ||
Formerly PetesEB
I also have a ticking coming from the engine when revving at about 2000 and it aint the lifters or injectors.....thought i could possibly be a manifold leak, or could it be something else
:gren: Weapon of choice. :gren: EB II, T5, Custom extractors, 2.5'' all the way thru, hardly legal tint, EL XR rims, on its balls, cold air intake + stainless heat shield. Custom boot garnish. |
12-10-2005, 01:55 PM | #13 | ||
Is it possible that number 2 is catching aginst something due to excessive lateral movement (broken or damaged spacing washer)or...damaged roller or....broken timing chain guide catching against chain etc??
12-10-2005, 02:13 PM | #14 | ||
XR8 v Lee. love you Lee
I have had this happen in a number of cars that iv'e had,
You will need 5 ltrs of diesel New oil filter Replacement oil Drain the existing oil out of the motor Leave the old oil fiter on Pour the diesel into the motor start the car and idle for a couple minutes and go for a shord drive not reving hard Drain the diesel and remove old oil filter 1/2 fill new filter with new oil and skrew on Replace motor oil The diesel has oil in its mixture to protect it enough to loosen any shyte in the whole motor, as well as the hydraulic tappets which are usally the culprit happy motoring :1syellow1
1993 EB2 FALCON S XR8 As original from showroom floor with all options Additions - Pacemakers turbo400 3" exhaust Custom cai prototype No 4 Stage 1 shift kit with neck brace Still to come DIVORCE |
12-10-2005, 02:21 PM | #15 | ||
likes falcon's
ive noticed mine doing this to, it only does it on any sort of throttle rolling along/idle it wont do it but it is annoying coz i know its there :(
gas and petrol
www.carhubsales.com.au |
12-10-2005, 02:55 PM | #16 | ||
Low and Loud
Ticking from the front of the motor? What about the Timing chain guide that has broken (common for eseries) and is rattling about...
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
12-10-2005, 02:59 PM | #17 | ||
Last warning
a timing guide probably won't sound like a ticking though.
if its a consistant tick then its gotta be something cylinder related. i know my exhaust leak deffinately sounded like a tick, just had to tighten all the extractor bolts up again.
31-10-2005, 08:20 PM | #18 | ||
just a thought check for loose spark plugs, wouldnt be the first time or last! or stray sparks from faulty leads etc.
31-10-2005, 10:24 PM | #19 | ||
mine used to do it so replaced the lifters then it only did it on start up so i dont know what the go was there now it only does it very very very rarely must have fixed its self
http://i11.photobucket.com/albums/a1...50/cartoon.gif |
31-10-2005, 10:42 PM | #20 | ||
if rockers have side way slop in them then that will most definatly make a loud ticking noise in it, ive replaced a few rocker gear for the same sideway slop in them making a ticking noise
No. Of Snapped Axles So Far: 2 |
01-11-2005, 02:55 PM | #21 | ||
blown i can't stop lookin at your intercooler
01-11-2005, 07:04 PM | #22 | ||
haahaha, gozza i got the same problem.
p.s thanks
04-11-2005, 04:23 PM | #23 | ||
Keepin' it real
Timing guides DO give off a ticking sound and if they are left long enough the chain will pick up the guide and spit it out the side of the timing case. Replacement of the guides (usually) requires dropping the sump. If you can fix it yourself its a bit easy and a bit cheap! That is providing that THAT is the problem!
04-11-2005, 09:08 PM | #24 | ||
Does anyone get the ticking noise when you first start the car up, especially when cold? i can always hear it in the morning when still cold backing down the driveway, and because its a tight area it sounds louder that what it really is. Im using Valvoline Enigine Armour, 15 -40. The car still hasn't ticked over 130,000km. Could I be having the same problem?
