Old 21-10-2011, 02:59 PM   #1
tj351
xt 500 P plater
tj351's Avatar
Default ford i6 VCT
whats the difference between a normal inline 6 out of an AU forte or a VCT 6 out of an xr or fairlane ?
cheers
low n loud
tj351 is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2011, 03:06 PM   #2
flappist
Default Re: ford i6 VCT
VCT, Variable cam timing.
In the VCT engine the cam timing can be advanced or retarded to allow for changes in gas flow at various rev ranges.
The AU had one cam for both inlet and exhaust, BA had 2 (1 for in 1 for ex)which were syncronised and then BF and later have 2 that are independent from each other.
Intec has fixed timing on 1 cam only
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2011, 09:06 PM   #3
Bossxr8
Peter Car
Bossxr8's Avatar
Cylinder head and rocker cover were quite different at the front. But it also had the tweaks the non VCT XR6 engine got like bigger valves etc and a bigger exhaust.
From memory everything below the head was the same.
Old 21-10-2011, 09:24 PM   #4
Jimmyd
Intech 157kw/357nm
XR6 HO 164kw/366nm
VCT Fairmont/lane 168kw/370nm
VCT XR6 172kw/374nm
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2011, 09:29 PM   #5
DJM83
Barra Turbo > V8
DJM83's Avatar
Originally Posted by Jimmyd
Intech 157kw/357nm
XR6 HO 164kw/366nm
VCT XR6 172kw/374nm
Intech 157kw/357nm
XR6 HP 164kw/366nm
VCT XR6 172kw/374nm
Not being picky
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
-2022 Hyundai Tucson Highlander Diesel N Line
