Old 11-12-2011, 12:39 PM   #1
muzzy
muzzy's Avatar
Default 5 Speed escort
HI Guys
I have fitted a 5 speed box to my RS project, I'm keen to here from anyone else who has fitted one, I have 2 questions
1 The centre console, how far back did you move it? and does it now look Ok or out of place?
2 The speedo drive did you use the orginal from the escort box
thanks
RS2000 5 speed
Twin 44idf webers + other goodies
muzzy is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2011, 07:49 PM   #2
T3man
T3man's Avatar
Default Re: 5 Speed escort
what box did you fit?
Old 12-12-2011, 09:22 PM   #3
muzzy
muzzy's Avatar
I have fitted a T9 Sierra box, .82 OD ( other 4 ratios are the same)
105K's will drop from 3500 RPM to 2870RPM
I practice fitted the centre console tonight and the mount brackets move back 25mm to line up, so the console moves the same, cant really tell the difference when compared to the ashtray/switch console
RS2000 5 speed
Old 12-12-2011, 09:45 PM   #4
Sprint
Sprint's Avatar
best to shorten the handbrake lever also,cut and shut does it
Sprint is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2011, 06:07 PM   #5
muzzy
muzzy's Avatar
I used a short shift lever, the stick misses Handbrake by a good margin
RS2000 5 speed
Old 13-12-2011, 08:38 PM   #6
T3man
T3man's Avatar
OK mate; sorry I can't help with your questions as I've only fitted Celica and Supra boxes.
Old 13-12-2011, 10:54 PM   #7
wicko
wicko's Avatar
I've got the T9Ford box from the Sierra etc. With factory gearstick it hit the handbrake - but putting a shorter shift in it solved that problem.
Originally I had the console moved back about an inch and there was a noticeable gap between the top of the console and the ashtray cluster. When I put it back together (car was restored) I got it to sit in the normal spot and it all looks 'factory'.
Speedo Drive or Cable ?? You'll find the Speedo cable from a Cortina suits as they are a bit longer.
You can get most of the stuff you need from Burtons in the UK
wicko is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2012, 06:37 PM   #8
Forte
G'day mate, currently doing this myself, and wondering the same questions. Also, did you have to put spaces between the gearbox crossmember and the mounting points? if so how much? also, how much did you have to cut the gear leaver hole back? any pics would be sweet
Forte is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2012, 03:10 PM   #9
muzzy
muzzy's Avatar
The rear mount moved back 45 mm, I cut the orginal mount off and fitted an automatic mount with 11mm packed plates to get the right JWA, and made reinforce plates for the floor
the stick moved back 70mm and the centre consul mounts 25mm (centre consul actually lines up better now than factory
send me a Private messgae with email and i will email mail you pictures
the speedo drive in the sierra box has 2 less teeth than the escort, i will swap them as i'm rebuilding the 5 speed anyway and fitting drain plug etc.
cheers
RS2000 5 speed
Old 19-01-2012, 03:23 PM   #10
Pazuzu
Found this online- it's for a conversion from Auto to T9, but may help you:
http://www.rsmotorsport.com.au/techn...Type9toMk2.pdf
Then there's this:
http://homepages.mcs.vuw.ac.nz/~kris.../gearbox.shtml
I'm still trying to get around to fitting my T9 to my Mk2. The bloke who sold me the T9 told me he had it in his hill climber for a while, which tells me there's likely to be problems! Let us know how you go, whack a few pics up on the forum for us all to see.
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2012, 03:45 PM   #11
muzzy
muzzy's Avatar
I have fitted the T9, job is finished except speedo cable
all removed now so i can start painting , I currently rebuilding the T9, I cant seem to post pictures or they are 2 big, send me a private messgae with email ,I'm happy to send pictures
Muzza
RS2000 5 speed
