Old 16-02-2012, 05:33 PM   #1
IJG033
Craazzee Barstard
IJG033's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Dave is an absolute wealth of knowlege.. GT stuff.
Default 3L V6 Main Cap Order
G'day all , can anyone advise me of the Main Bearing cap order , My brother pulled the engine apart & I'm rebuilding it but need to know the order ,
Dave
IJG033 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2012, 06:50 PM   #2
cosworthfreak
cosworthfreak's Avatar
Default Re: 3L V6 Main Cap Order
Hi Dave,
The Capri V6 workshop manual says to tighten the main cap bolts "evenly" to 55-60 lbs/ft, probably in stages. I'm not aware of a specific order, but seasoned engine builders may have their own tips. The manual also states crankshaft 'end float' on these should be between 0.003 and 0.011 in.
There is another rebuild article which I found a while ago which states 76-83 lbs/ft and end float of 0.003 to 0.006 in, although that rebuild was for the D-port version of the engine.
Jamie
cosworthfreak is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2012, 09:49 PM   #3
bawag
bawag's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Providing easy to follow photo tutorials for members on how to replace tierod ends on a Cortina.
Do you mean the tightening sequence?, if so to avoid bending of the crank and block work clock wise from the centre cap to the outside in a circular pattern, i normally start with a 3/8 drive air ratchet and move to a torque wrench but i stagger the torque in thirds, i.e if the final torque is 90 Nm, do the first circle at 30 Nm then 60 Nm then the final 90 Nm.
bawag is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2012, 08:24 AM   #4
IJG033
Craazzee Barstard
IJG033's Avatar
Thanks guy's for the Responses but what I need to confirm is the order of the Main caps front to rear , I have all the general specs for the engine but not the cap order ,
Old 17-02-2012, 11:38 AM   #5
cosworthfreak
As a starting point, cap number 2 (from the front) holds the thrust washers.
From memory the caps are marked 1 to 4, which would be front to back, but I haven't pulled one of these apart for a while.
