17-01-2012, 10:46 PM | #1 | ||
351XB - Underbelly II Car
Hi all ... can someone tell me How much modification to fit AU seats into an ED ?
Ive heard that you may even be able to just unbolt all the foam padding from both seat frames and swap them over for an easier conversion , is this true?? any ideas? Cheers.
FALCON XB 351 - UNDERBELLY II CAR Last edited by samsy351; 17-01-2012 at 11:12 PM. |
18-01-2012, 06:17 PM | #2 | ||
Oo\===/oO
Just swap the 'feet' of the seat rails over.
18-01-2012, 10:46 PM | #3 | ||
FALCON XB 351 - UNDERBELLY II CAR |
19-01-2012, 12:27 AM | #4 | ||
Pro Street Au Ute
Why. and then no not really at all. ba seats will go straight in with a spacer on the inside rear leg. au seats are in my opinion th worst ford seat and rail setup ever. And theres no swapping the feet over, have a look at the two seat design they're completely different and they will sit way way to low.
19-01-2012, 09:08 PM | #5 | ||
Just considered AU seats cause I could get some cheap thats all. Its just for the "run-a-round" ...the current seats in it are *****.
Thanks for the info .
20-01-2012, 06:38 PM | #6 | |||
Oo\===/oO
Actually, its is just a case of swapping the feat over. Its been done before...even threads on it on fordmods. Its the same way people put EF-EL seats into the EA-ED's (unless you want to weld the floor hump in) So, again, to put Au seats in, use the feat from your ED seats, the are rivited/welded from factory. IF you have a good welder (not a gassless mig lol) weld the ED feet onto the AU rails.
20-01-2012, 10:25 PM | #7 | ||
Thanks Nikked, .....Ive also come across some BA seats cheap aswell but they are from a ute .. are the ute ones the same as a sedan??
21-01-2012, 01:12 AM | #8 | |||
Oo\===/oO
Keep in mind, if they are electronic, you'll need to wire them up.
24-02-2012, 12:33 PM | #9 | ||
Is there any difference in putting ba seats into an xh? Not sure what the floor pans like?
FG MKII XR6T UTE |
