I understand that all cars have to have a minimum ground clearance. Can any FF member tell me where said ground clearance is to be measured? On a 1993 Ford Telstar but also on any car?
Far aim aware it's from the chassis to ground could be wrong tho!
Lowest point of vehicle in NSW ... could be exhaust. It depends.
Last time I saw RTA do this check ... they slid a roller-type device under the vehicle and if it touched anywhere ... you were too low. 100mm is the legal lowest here.
lowest point apart from suspension arms
#5 | |||
In QLD:
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
thanks people. I need this to work out how far my car is from standard ride height as am replacing tired (collapsed) springs with Kings and new Ultima struts. Not cheap...
in NSW its 100mm from the lowest part of the car. So esentially if you can roll a coke can on its side under the car & dont hit anything you will be fine.
If your unsure call up the RTA or Police Highway Patrol & they should beable to tell you |
#8 | |||
Im pretty sure its the same in VIC. 100mm from the lowest point.
Is it taken when the car has a full load? |
Force Fed Fords
In Victoria 100mm from any part of the sprung part of the vehicle, anything north of the springs including exhaust, body kits etc
2021 Focus ST-3 Mountune Enhanced |
Oo\===/oO
100mm from the lowest point of the car, debatable if that means mudflaps. But it includes exhaust and hangers, anything... oh, and that's with a full size passanger and a tank of fuel.
I did see something somewhere about it being measured within so many mm of the axle centerline, but im not sure enough about that. A coke can is 110mm tall, if you cant fit one under, its a good sign that you've got an illegally modifed car. I can't fit one under mine ![]()
Rob
in s.a. there are 2 measurements to be aware of for vehicle height. ground clearance seems to be the same as other states but the car also must meet a certain 'hub to guard' height. thats centre of hub to lip of guard. your local tansport authority should be able to fill you in on what that measurement is.
