Old 17-02-2012, 12:46 AM   #1
fonfe
RS shop's technician
Default 1980 cortina engine options
Right lads got myself an ole Tina 2l 4speed.... I'm well aware what my engine options would have been back in the uk (v6 24v cosworth motor all day long as its cheap as chips)
But seeing as I'm no more in the uk what are my options over here?
fonfe is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2012, 01:36 AM   #2
Neale
Neale's Avatar
Default Re: 1980 cortina engine options
depends on what state you are moving to & what they will let you get away with. Some can be very strict & can cost alot to get engineered.
If you are going to go to those lengths a small block V8 is the most common.
In Australia "Cosworth & "Cheap as chips" aren't used in the same sentence.
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2012, 01:52 AM   #3
fonfe
Am in Victoria?
Am aware cosworths are a huge cost over here same as the the uk....ok a LOT more here but the v6 motor is a few hundred quid still in the uk so I could ship one over but want to know the engines that are a common swap over here before I go through all that effort.
Like what's a common oe swap on the cortinas here?
Old 17-02-2012, 11:49 PM   #4
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
it may be worth seeing if you can get a 2.8 v6 over. not sure how much they cost etc, but it is a lovely motor. loads of low down torque and sound lovely.
1965 Ford Anglia
1980 Ford Escort RS2000
2006 Mazda SP23
2012 Ford Focus ST
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 12:51 AM   #5
XP6
Formerly ST170ish
XP6's Avatar
XR6 turbo motor
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 01:55 AM   #6
fonfe
Yeah but mate the 2.9 cossie versions gives you 203lbft!
Old 18-02-2012, 06:34 PM   #7
gassed250
Originally Posted by XP6
XR6 turbo motor
that wont fit without massive firewall mods
gassed250 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 09:47 PM   #8
fonfe
Well from lack of options here think its going to be a zetec jobby, easy enough to turbo....crank and rods good for 300bhp as OE items. Only thing is wow those engines are pricey over here!
If I change the engine though do I have to put a cat on it as the engine would of had one to start ith?
Old 22-02-2012, 09:17 PM   #9
pcman
250crossflow, 4.0 from e series falcon, 4l dohc from ba/bf/fg , any v8 has been done clevo, windsor, lexus, rover, sr20, fj20, 1jz, 2jz, 13brotary
just about any engine you can think of has been put into a cortina
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2012, 09:33 PM   #10
FreddyDUZ747
FreddyDUZ747's Avatar
Beams Racing 2lts Yamaha headed engine.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2012, 09:35 PM   #11
Legit290
Legit290's Avatar
250 2v with 465 holley 4 barrell, triple webbers or a pump
11 second car with a 12 second driver
Blown BA GT mk 2 manual in Envi
Legit290 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2012, 02:12 AM   #12
Kevaclone
Kevaclone's Avatar
Guy at the end of my street has a TE with 4.9L(302cu) clevo
very plain looking alloy wheels
4.9L badges and twin exhaust(and note) are the only give away
Some 351 internals, big carb, cam and good alloy heads should see it get going nicely
Since the TE was available with a 4.1L 6 anything to that size should be no problem.
I'm thinking the supercharged mustang 4.6L V8 would be a nice goer
03 BA XLS 6cyl Ute-Mercury Silver
04 Subaru Liberty GT Premium
99 Toyota 105 series Cruiser TD
99 5.8M Profish plate alloy carport decoration
Kevaclone is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2012, 10:35 PM   #13
gassed250
pretty sure that would have been a dealer special
Old 26-02-2012, 05:05 PM   #14
allanv6gt
Tippy-tronic Free Zone
302 clevo is a common conversion, and period 4.9 badges available from rare spares
......but the Mustang 4.6 supercharged would be really modern, just keep it a sleeper....then ...Surprise !!!! (vroom, gone...)
Old 09-03-2012, 12:52 PM   #15
futura
futura's Avatar
good luck trying to fit a 4.6L
futura is offline   Reply With Quote Multi-Quote with this Post
