28-05-2012, 10:15 AM | #1 | ||
Former BTIKD
The Headlights on the barge are getting a little hazy and I'd like to try cleaning them.
I know there are a number of Headlight cleaning kits on the market but has anyone used one that they would recommend or ones to stay away from ?
28-05-2012, 10:40 AM | #2 | ||
Just another mock-up..
I used Meguiars PlastX on my headlights mate as mine had hazed up too..
Seemed to do quite a good job of cleaning them up.. I applied it by hand.. From memory its around $20 a bottle..
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
28-05-2012, 10:49 AM | #3 | ||
2 for meguiars plastx.......lady friend used it (after I recommended a recommendation from Dave) on a hyundai
lights were very bad.....first go made 100% difference, second made them like new
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! |
28-05-2012, 10:54 AM | #4 | |||
I've used Mothers plastic polish. Worked OK.
I love Holdens.... |
28-05-2012, 11:25 AM | #5 | |||
Former BTIKD
From what I've read most use a system with sandpaper then coat the lens with a liquid, but the Megs one is just in a bottle. Correct ?
28-05-2012, 11:27 AM | #6 | ||
straight from the bottle and a can of elbow grease!
28-05-2012, 11:34 AM | #7 | ||
Mother's Plastic Polish. It worked well but it took some rubbing!
28-05-2012, 11:46 AM | #8 | ||
FPV GTR
Plastx will do the trick on hazy head lights with a few applications. If they have started to craze and get micro cracks in them you will need to use wet and dry to remove the crazing and then a couple of polishes to remove and then refine the marring left behind from the sanding. Using a machine is fine, but I would only recommend it if you have some experience.
- FPV GT RSpec - - Chill SZ Territory Titanium -
The Family Bus - Veridian Green PJ Ranger XLT - The Work Truck |
28-05-2012, 12:27 PM | #9 | ||
Petro-sexual
Wolfgang make a good restoration kit that also includes a plastic sealant.
It worked very good on my original headlights, but the sealant needs to be re-applied every 6 months or so to keep the yellowing down. Now I use this method... http://www.autogeekonline.net/forum/...lant-idea.html Took a little to get used to but works extremely well once your used to it. For this I wet sanded from 600 to 2000, then applied the coat. No polishing required to get a perfect finish. So far the coat I have on my headlights is still going strong after 11 months and nothing extra done to them apart from washing. |
28-05-2012, 04:14 PM | #10 | ||
Former BTIKD
The lights are only very slightly hazy so sounds like Meguiars is the one to go for.
28-05-2012, 09:26 PM | #11 | ||
Peter Car
Try RaineX, the stuff you put on your windscreen to make the water bead off. Someone on here recommended it so I tried it, and it worked a treat.
Just put a bit on a rag and rub it on, the rag ended up green from the grime it got off. $10 a bottle. |
