Hi all
Just wondering if anyone else has had the rear washer jet freezing up? I live on the other side of the Blue Mountains and on the (all to regular) frosty mornings we get here the back window of my MA XR5 is a sheet of ice. I had read somewhere that the washer jets were supposed to be heated but this may only be the front although these have also frozen on a couple of occaisions Any advice on what I could put in the washer water to prevent it from freezing that wouldn't be a risk to the paintwork? Thanks! |
Hey Mate,
Just lifted the bonnet on mine and the washer jets are not heated, no wiring loom there. On my previous Passat it had Heated (Fan-Type) Jets. Although for me I was never subject to the same temperature drops that you are faced with. I am sure you will find answers if you look on the Ford UK sites / forums. Maybe you could retro-fit the heated washer jets as a side project? Maybe ask your local Ford Parts for what windscreen additive they provide. I myself am still using Genuine VW Windscreen Clear Concentrate Part No. G 052 164 M2. It has frost protection to -70degrees and is lemony fresh to boot!
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please! |
Just located on a Ford UK site. Premium Washer Fluid Part No. F1388438 (1L) this has frost protection to -55degrees as per the bottle (not description). Maybe see if Ford OZ can source for you, or try autObarn / Super Cheap etc. Or just buy the same as I use from VW for about $12 a bottle (1Litre).
![]() Join Date: Oct 2006
You can buy add ons to heat the washer fluid. Either electric (more instant) or ones that have a coolant heat exchanger (don't work until the coolant is hot).
eg http://www.autoanything.com/driving-...A5007A0A0.aspx http://www.closeouts.midwestbusparts...&products_id=1 http://www.kraftpower.com/carlor/topstart.html http://www.btinternet.com/~madmole/H... Courtesy Lamp But also choose a washer additive that contains antifreeze. Per the last link Ford also supply heated jets on some overseas models and retrofitting them might be the easiest solution. Also http://www.pumaspeed.co.uk/product-O...Focus_1044.jsp
regards Blue Last edited by aussiblue; 08-07-2012 at 01:41 PM. |
Some great info there Blue. Glad to see Ford now also offer a Fan-type washer jet. Might look at grabbing these, not sue about the hassle of wiring up the jets though.
Thanks for the tips guys!
I had asked at the local auto shops for washer fluid with anti-freeze and got some blank looks If I don't have any luck with the Ford Dealer I'll chase up give the VW fluid as there is now a dealer up in Bathurst. |
add metho too the water, alcohol % lowers the freezing point
#8 | ||||
Captain Malcolm Reynolds
Get rid of the water altogether and put vodka in there. Won't freeze.
The bonus is you can stand outside your car when you're chilling with mates and add to your Maccas Coke with the press of a button.
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car) Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla Quote:
RS shop's technician
You do not need to add any additives to your washer system to prevent freezing, only increase the concentration of washer fluid to water mixture.
Washer fluid contains alcohol to prevent freezing, you have too weak a solution as your probably not factoring quite how much your washer bottle holds
Advertising removed |
Hi Guys, thanks for the posts, Does anyone have any idea what the capacity of the washer bottle actually is (So I can get the mix right)
about 3-4 liters i think. never actually filled one up from bone dry
