Old 03-07-2012, 07:31 PM   #1
muzzy
muzzy's Avatar
Angry RS 2000 or 2lt clutch cable
Hi All
I have purchased from " Burtons" a RS2000 clutch cable, Just beware it wont fit the aussie model, or any 2lt escort it only good for the Alloy sump alloy bellhousing model ( they dont say that in the add, there responce was send it back at my cost, so 2 things
1 If you have the above please PM me and I will sell you a cheap cable
2 Does anybody know where I can get a Aussie clutch cable ( its longer by 65mm than the pommie one)
thanks
RS2000 5 speed
Twin 44idf webers + other goodies
muzzy is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2012, 08:51 PM   #2
JimStone
Default Re: RS 2000 or 2lt clutch cable
I've used the Flexdrive CC118 in the RS2000 for the last 15 years no problems
http://www.ebay.com.au/itm/FORD-ESCO...item43a344b8e0
Have also heard of people using the longer Cortina 2lt cable (1.2mtrs) to reroute around extractors and such.
http://www.ebay.com.au/itm/FORD-ESCO...item5890bb2975
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2012, 09:01 PM   #3
JimStone
Try Stewart at SMCKA - top service, good prices and quick dispatch. All parts I've gotten from him have been good quality and fit no problems
http://classicescortparts.com.au/ind...=530&Itemid=93
Old 03-07-2012, 09:35 PM   #4
Neale
Neale's Avatar
second that SMCKA is good, & your not the first person that I know of to have had dramas with Burtons recently
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2012, 09:01 AM   #5
wicko
wicko's Avatar
I bought the Burtons Clutch cable and it fitted fine. I also bought a speedo cable and the connection for the Gearbox was too thick - but I filed it down and its now fine.
wicko is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2012, 10:31 AM   #6
shepv8
V8's for ever
Very good advice from the guys to buy from Smcka. He is a good source of knowledge on parts. When you buy from burtons you need to order for mk2 2 litre escort, not rs2000. theres a few other parts like suspension TCA's and engine parts that are different as the pommy RS's were a bit sportier spec, ours are just dressed up standard MK2 2 litre escort rally packs.
shepv8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 10:36 AM   #7
CSWTH1
Becossie
CSWTH1's Avatar
Smile Re: RS 2000 or 2lt clutch cable
Adelaide Cable Co @ Regency park will make you any cable you just need to take a pattern or the originall for him to copy it
good luck
CSWTH1 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 11:53 AM   #8
ESS KEE
ESS KEE's Avatar
it's actually Stephen at SMCKA and he is a top bloke to deal with. have bought a couple of things now and it's never been a problem even me being in WA and he's always glad to help.
cheers
Chris
could also try Yesterford
Yesterford
Contact details
Address: 1 21 BURGESS RD, BAYSWATER NORTH, VIC 3153
Croydon VIC, East VIC
Tel: (03) 9761 4714
Knowledge is knowing a tomato is a fruit, wisdom is not putting it in a fruit salad
ESS KEE is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2012, 07:17 PM   #9
muzzy
muzzy's Avatar
I got the correct one from Smcka all good now
RS2000 5 speed
