I'm thinking of buying an NF Fairlane at a good price . as much as I love my XR6 I haven't had an 8 for a while and want one to play with ( I'm still keeping the XR as a daily driver)
I have limited experience with injected Windsors what mods do you guys recommend cam is out of the question as I don't want to dump the AC gas, heads could be an option but probably looking for simpler stuff to start with. I know the stock EF / NF V8 are a bit asthmatic so I am thinking of exhaust / intake to start with. A few questions
[SIGPIC][/SIGPIC]
not here much anymore
Being the 'experienced' member you are I would have thought you'd put this in the correct section...
But anyway: what is involved in fitting an AU intake setup ( complete from manifold to air box) I have heard you need to do some mods for the explorer manifold You have to fit the IAT sensor into the manifold as that is how it is on the E series. Or you can extend the looms and run it in the intake pipe as per AU spec. I have looked at the Redback site and the have no Fairlane listings are the Fairlane exhausts the same as the wagon due to both being longer wheelbase? No, different from what I know. I am looking at a cruiser with a nice note and good low down grunt not a top end screamer with this in mind what extractors would best suit this? Tri-Y's are generally regarded as having more low down torque as compared to 4 into 1s. I have always had 4 into 1's though with no complaints. are J3 chips worth the effort? if so who would you recommend for this? No. are the 1.72:1 roller rockers going to give much gain and will I need a taller rocker covers? Yes and yes I think you would. But why you would bother putting a good set of rockers onto E7 heads is beyond me.
2024 F150 XLT
Barra Turbo > V8
Just fixed it Aust
![]() As you were.
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
#4 | |||
thanks for that you have covered it all well. in regard to the rockers that's for if I decide to go with the GT40P heads ( wish list if I get some cheap enough)
[SIGPIC][/SIGPIC]
Peter Car
I've done the Explorer conversion, there's 3 or 4 things different.
One vacuum hose needs to be joined to another with a T piece, the IAT needs a hole to be drilled and tapped into the number 5 runner (putting it into the intake pipe may effect temps), the AU throttlebody needs the TPS sensor bolt holes ground out as far as they can go to get them set in the right voltage range, and the EGR coolant lines need to be looped together because the AU EGR spacer doesn't have EGR provision. Thats about it really although I may have forgotten something. Its not that hard. Just do the bolt on stuff, XR snorkel and filter, pacemaker extractors and twin and a quarter inch exhaust, Explorer intake and AU throttlebody and MAF, underdrive pullies and get it tuned. That should wake it up nicely. Roller rockers, heads and a cam if you want to go further. |
Should have bought my ltd, sold it for $5500 with all the mods.
I had a e series cat back fitted but exhaust shop had to cut it and lengthen it. Try y headers and 200 cell cats. Gave it a great sound and more low end torque. Also added 3.45 diff gears and made a big difference. Ended up with a 0-100 time in the low 7s. 7.2s It was a sweet sweet cruiser and new owner calls me to let me know what I'm missing. Get diff gears and full exhaust and intake. It will be a great cruiser. |
#7 | |||
[SIGPIC][/SIGPIC]
