ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link |
29-12-2012, 11:48 PM | #1 | ||
Hi Guys,
My partner got me a Parrot MKi9200 for Christmas along with the ISO2car (86120) cable to suit my 03 BA XR, what she did not realise until I opened everything is that the ISO2car documentation had in small print that it will not suit some vehicles with amplified systems, and as my BA has premium sound it is amplified.... Before I even think about installing the Parrot, I thought it better to check with you guys if this ISO2car cable will work with the BA premium sound...or will I need a different ISO cable, or will it need to be direct wired in? Wy couldnt you guys have a shop up my way lol Any assistance greatly appreciated....cheers |
30-12-2012, 01:50 PM | #2 | ||
Hi. The parrot hands free kit works well with the BA/BF falcons. The power earth and mute wires all connect to a four pin plug behind the fuse box. Use either the grey grey/black OR the white white/black speaker output wires to the 2 pin plug also behind the fuse box. For music streaming use the white (l) and red (r) line out wires to the aux in plug behind the fuse box. Red to orange, white to white and the black and brown wires join together and then connect to tha last 3 wires in the aux plug. you then turn OFF mute when streaming in the parrot and switch on aux in by pushing AM twice on the radio. Cheers MD
31-12-2012, 09:21 AM | #3 | ||
Cheers Michael, so I am guessing that means the ISO plug is no good to use then.....?
31-12-2012, 02:38 PM | #4 | ||
Hi. Seeing there is no iso plug on the falcon there is not a lot of need for one but if it is a small adaptor harness it may be preferable to cut it up to make it fit the ford than the harness supplied with the parrot. Cheers MD
31-12-2012, 02:52 PM | #5 | ||
the iso2car harness should work and clip straight in to the plugs under the dash
31-12-2012, 05:08 PM | #6 | ||
Thats what I thought also mitch, but it says not suitable for amplified systems, but is for the El through BF models with an 8+8 pin, so just wanted to chec k first...ASL install these I think
31-12-2012, 05:45 PM | #7 | ||
Hi. the BA/BF uses a plug mounted to the dash which the icc locks into. this plug is fixed in its location and the layout in nothing like an iso plug. See here for the BA/BF plug http://www.fordforums.com.au/vbporta...?articleid=571 .
See here for iso plug and socket http://www.google.com.au/imgres?star...37&tx=53&ty=70 . See here for BA/BF phone plugs http://www.fordforums.com.au/vbporta...?articleid=566 . iso2car cables are used between car radio and factory wiring to enable the connection of iso completable hands free kits. As yet no one does an iso2car for the BA/BF because it doesnt need one. see here. http://www.strike.com.au/products/KRAM-Cables . Cheers MD
31-12-2012, 07:38 PM | #8 | ||
Thanks Michael, that made it very clear lol...
the only confusion now is slight differences; I have 2 line outs Right (blue+ and green-) and Left (white+ and brown-) to which I would say blue to orange and white to white, join green and brown together and then join them to the last 3 wires in the aux plug, is that correct....? |
31-12-2012, 09:26 PM | #9 | |||
02-01-2013, 08:22 AM | #10 | |||
Sponsor
we can supply you with the plug and play cables $75.00 plus $15.00 freight please call 0397991444 to arrange a phone order cheers fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS AUTHORISED FORD REPAIR CENTRE website: www.aslautomedia.com.au email: info@aslautomedia.com AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN |
03-01-2013, 07:56 AM | #11 | ||
Hi Fadi,
Very keen if it is to suit premier sound system and not the iso2car cable that I have already got? Will give you a call today....
BA XR8 - BOSS 290, BIG Mouth CAI, RDA high flow system 2007 Territory Turbo Ghia |
04-01-2014, 01:52 AM | #12 | ||
Do these plugs also refer to the territory?
04-01-2014, 09:11 PM | #13 | ||
Hi. If it has the same ICC as a BA/BF falcon. Cheers MD
15-12-2016, 03:04 PM | #14 | ||
08 Territory AWD Ghia
16-12-2016, 08:44 AM | #15 | |||
Sponsor
Please see link below, ASL is having a 15% off this month http://www.aslautomedia.com.au/parro...iring-harness/ cheers fadi75
22-11-2017, 09:41 PM | #16 | |||
22-11-2017, 09:47 PM | #17 | ||
I would honestly recommend not bothering and just get the adapter you're going to save yourself a major headache and it's worth shelling out the $75 just for that.
Buy yourself an early Christmas present 🎁 |
22-11-2017, 09:51 PM | #18 | ||
oh and they're at %15 off at the moment for Christmas too!
23-11-2017, 08:53 AM | #19 | ||
No thanks..i'd rather spend a few hours wiring it up than spend $80 on something that probably cost's them $10 - $20 to make besides that i just don't have the money to buy one.
23-11-2017, 10:22 AM | #20 | |||
Sponsor
Not a problem, good luck Cheers fadi75
23-11-2017, 11:20 AM | #21 | ||
All i need is a wiring diagram Michael explained the wiring here but i am trying to find out if someone has a wiring diagram for it.
23-11-2017, 11:33 AM | #22 | |||
FullSizeRender.jpg |
23-11-2017, 12:12 PM | #23 | |||
